Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 09-23-2008, 02:42 PM
Bow's Avatar
Bow Bow is offline
Junior Member
Bow is on a distinguished road
Default I have a Question about "Dead Key" and "SWING"
I have been playing with radios for the better part of 20 years... I'm a HAM, Avionics Tech (by education and trade) and a 11 meter Op...
But what is this Dead Key and Swing thing?
Dead key: Un-modulated Carrier
Swing: Modulated Carrier (Peak to Peak)
If you have a stock CB that has an Un-modulated carrier (Dead Key) of 4 watts and a Modulated carrier of 16 watts PEP (Swing?), you then have 100% modulation...
If you have the same radio modified for say... a 2 Watt "Dead Key" and 37 Watts of "Swing"?
Wouldn't you have a lot of over modulation,splatter, and the ability to to get a "Worked all Toasters" award from your neighbors?
What is the point of a low "Dead Key" and a big "Swing"
Someone please educate me on this...
  #2 (permalink)
Old 09-23-2008, 03:19 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
Oh, I think you've probably already got the education. It's the other ones who need it.
  #3 (permalink)
Old 09-23-2008, 03:43 PM
Senior Member
moleculo has disabled reputation
Default
That's awesome. I'm going to use that one.
The only reason I can think of why people want to do this is so they can drive the snot out of a transistor amp that can only handle a carrier of a couple watts. Of course the transistors used in that amp was probably never designed to driven like that either, so in the end you get to work even more toasters.
  #4 (permalink)
Old 09-23-2008, 03:54 PM
gc505 is on a distinguished road
Default
My guess is so that they don't sound like the tired, quiet hams on 10 meters. If that's what they wanted I'd imagine they'd at least get a tech ticket and hang out in 28.3-28.5 Mhz.
The overmodulated splatter has become a 11 meter trademark, especially with the "power boys" (and wannabe power boys) of CB.
I'm a very active ham (W9SFA) and I'm also very active on CB, and I'm proud of my screaming loud, overmodulated signal on that band, because it fits in with the others. But when I get tired of hearing overmodulated, crappy signals (like mine) I go catch a QSO on any of the HF bands where it's (sometimes) more civil and the signal quality is often unsurpassed.
We already know what the 11 meter band is - and what it isn't. It's effectively the unregulated ghetto of the HF spectrum. I guess that makes me a part time, 11 meter ghetto rat.
I love the terminology!
  #5 (permalink)
Old 09-23-2008, 04:14 PM
QRN's Avatar
QRN QRN is offline
Administrator
QRN has disabled reputation
Default
I don't care what band I operate on I absolutely refuse to have an over modulated splattering signal.
Well there was that ONE time I tried out my Heath DX-60 on 11m. That 12 watt carrier grid modulated to 50 watts caused quite a ruckous for several channels either way and I did get a little kick out of it but I quickly came to my senses.
  #6 (permalink)
Old 09-23-2008, 04:22 PM
Senior Member
Default
'WATT' = Worked All Them Toasters
'WAHA' = Worked All Hearing Aides
'WATF' = Worked All Teeth Fillings
'WACS' = Worked All Computer Speakers
'WAS' = Worked All Stereos
and the really hard one,
'WACCS' = Worked All Car Computer Systems
All the above require documentation for confirmation.
  #7 (permalink)
Old 09-23-2008, 04:50 PM
QRN's Avatar
QRN QRN is offline
Administrator
Default
You forgot WHAT= Worked Hardly Anything 'tall ('tall=at all) Usually because they can't understand you and keep saying "What? What?"
  #8 (permalink)
Old 09-23-2008, 05:06 PM
Bionic Chicken is an unknown quantity at this point
Default
Years ago I had a 4-1000 amp and lived in the city. I would wait until after midnight to key it to limit RF interference with toaster, etc. My next door neighbor came over one morning and asked if I had been on the radio earlier in the day. I told him yes. He said he figured so because around 3 am he heard some racket in the front room of his house and went to investigate. He found the coffee pot (that had been set on a timer) brewing coffee an hour and a half before the set time. After doing a little testing we found I could not only turn his coffee pot on but could also make his VCR come on and start recording. Luckily he was a decent fellow and it was not a big problem.
  #9 (permalink)
Old 09-23-2008, 05:15 PM
Rf Engineer
freecell is on a distinguished road
Default
"What is the point of a low "Dead Key" and a big "Swing"...."
conservatively speaking it started out as a method by which 4:1 peak-to-carrier could be produced by an amplifier driven well beyond the middle of its power output range whereas most well designed amplifiers will mimic the ratio established by the transmitter almost exactly if not excessively driven.
as time passed by it just turned into stupid.
if anyone is still confused about the proper peak-to-carrier power relationship of an am transmitter just visit the chart in the middle of the page linked to below.
Transmitter Power & Harmonic Line-Section OverSampling
  #10 (permalink)
Old 09-24-2008, 07:40 AM
Bow's Avatar
Bow Bow is offline
Junior Member
Default
Quote:
EXACTLY!
I have never quite figured that out.. I love the "Break 19 for a Radio Check!"
"Well, your over modulating, very tinny, sounds pretty rough... roll your mic gain down..."
The reply is usually... "What?"
Reply
Bookmarks
Tags
292 radio shop, deadkey & swing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
