Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #31 (permalink)
Old 10-15-2008, 12:38 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
If you know where the noise is coming from, why not stop it (or reduce it) at the source, if you can? Isolate/by-pass/filter the 'XM' thingy's power lines. Moving that power source from the vehicles wiring by moving it to the battery isn't really removing it from the vehicle's wiring, just changing where the power happens to be tapped from that wiring. If that 'XM' thingy is putting noise into the wiring now, it certainly can do the same thing from the battery too. Making that move might make disconnecting any 'standby' power easier, but it isn't really 'fixing' anything. Not being familiar with any of the 'XM' stuff, will it loose it's programing by doing that? (I don't know, that's why I'm asking.)
  #32 (permalink)
Old 10-15-2008, 01:21 PM
Senior Member
steved is on a distinguished road
Default
The XM and the radio are hooked to power at the same location...I was just going to experiment.
The XM cigarette power adapter is the actual cause (it causes issues with the XM off), not sure what else to do but live with it.
  #33 (permalink)
Old 10-15-2008, 02:14 PM
Senior Member
Default
The first two things that come to mind is 'live with out it', or gently explain to it what you will do to it with a very large hammer if it doesn't straighten up. After that, it gets $ort of complicated. $ounds like another power supply for that 'XM' thingy might be an option. Don't take that as a good idea, it probably i$n't.
Reply
Bookmarks
Tags
292 radio shop, static?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
