Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 10-02-2008, 07:19 AM
Senior Member
steved is on a distinguished road
Default static
I think the answer to my problem is lack of chassis grounds...
I have static in my receive, a lot of it, as in around 7 S-units. I figured it was from a cellphone charger and XM receiver (unplug either one and it subsided). However, I can also simply place my hand on the radio and the noise decreases.
The radio is a HongKong 29 (similar to a Philippines), the setup is a 29/2-pill/Wilson 1000. The only grounds either the 29 or the 2-pill have are through their respective power leads (the radio is mounted to a plastic console, and the 2-pill is sitting on the floor). The 1000 has an added ground wire from the magnet's bolt to the vehicle's body. It does this regardless of whether the 2-pill is hooked up or not, so the amp is not likely the issue.
I'm figuring that since the chassis isn't ground well, the case isn't blocking errant RF? And by touching it, I'm closing the "ground" circuit?
Does this sound plausible?
  #2 (permalink)
Old 10-02-2008, 09:30 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
When all the noise is happening, what happens if you disconnect your radio's antenna and unplug it?
__________________
No trees were harmed in the sending of this post; however, many electrons were inconvenienced.
73 de K7KBN
  #3 (permalink)
Old 10-02-2008, 09:44 AM
Senior Member
Default
Quote:
Have not tried that, will do that on the ride home tonight...
I guess I don't understand why touching the radio causes the static to decrease...and it is consistent, I touch the radio and the noise decreases every time.
  #4 (permalink)
Old 10-02-2008, 10:06 AM
Senior Member
BOOTY MONSTER is on a distinguished road
Default
disconnecting the antenna will tell you if the noise is comming in through the antenna/coax or the electrical system . always good to know where/what to fix befor just changing things
__________________
Frank Zappa observed, "It's not getting any smarter out there. You have to come to terms with stupidity, and make it work for you."
  #5 (permalink)
Old 10-02-2008, 10:37 AM
Senior Member
Default
I understand that, but if it was coming in through the antenna, touching the radio should make no difference?
  #6 (permalink)
Old 10-02-2008, 12:09 PM
Rf Engineer
freecell is on a distinguished road
Default
just follow the booty man's instructions and let us know the results. in the meantime maybe you can explain to us just exactly how the dc power connections are routed. you most likely have multiple installation errors contributing to this.
  #7 (permalink)
Old 10-02-2008, 12:27 PM
Senior Member
Default
Some background: I've had this 29 in here before without this problem, then a 3300HP, then a Cobra25, and my Uniden 76. I put the 29 back in after trading some radios...I intend to install a Uniden Grant before too long.
The only one that had issues was the 25, and it was ignition noise coming through the power leads. All these radios used the same power leads and same antenna (coax was replaced a year ago). Things that changed since then were the addition of the XM receiver, that's about it..the XM is causing the noise and touching the radio makes most of it go away. And just to clarify, its not ignition noise I'm hearing, its white noise.
The radio is hooked into the car's "accessory on" circuit, not the best but it has not provided any issues until this. In fact, its the same power cord I've used on all the others. It is a soldered connection with a 7A inline fuse.
The amp, again I've had it completely out of the circuit, is direct to the battery...number 8 wire, 40A fuse, and a set of quick connects at the amp. As stated, the symptoms exist with the amp sitting on the bench in my garage and the car driving down the highway...so I'm confident that its not causing any of these symptoms.
  #8 (permalink)
Old 10-02-2008, 01:09 PM
Rf Engineer
Default
  #9 (permalink)
Old 10-02-2008, 03:35 PM
Senior Member
Default
With the antenna disconnected, no noise. Even with the gain up and the NB off, I only get a very faint sizzle. And you need to really listen to here that.
Plug the antenna in and I have 7 s-units of white noise. Touch the radio or the mic and it drops significantly. I found tonight that by touching the screen on the skythumper, the noise drops to an expected 1 s-unit. I also found that just touching the mic cord will drop the noise level. That's a 6 point drop.
And just to make the point, this is a DTB radio-tuned radio. Not some hack special. And I don't think its the radio by any stretch of the imagination.
  #10 (permalink)
Old 10-02-2008, 03:40 PM
Senior Member
Default
Reply
Bookmarks
Tags
292 radio shop, static?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
