Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 10-11-2008, 09:51 PM
Bow's Avatar
Bow Bow is offline
Junior Member
Bow is on a distinguished road
Default NPC-RC Modification for a PC122XL ??
I have a Uniden PC122XL that I am experimenting with.
I actually did the "Handy Andy" mods to the power section of it for starters ( PC-122 Power Mods and miscelaneous stuff... )...
But I want to make this thing louder. I am also planning to see how wide I can get the audio bandwidth... Just because.
Does anyone know the NPC-RC mod for this radio?
  #2 (permalink)
Old 10-17-2008, 12:11 AM
Senior Member
moleculo has disabled reputation
Default
Check this page...lots of info for that radio:
  #3 (permalink)
Old 10-17-2008, 04:17 PM
Senior Member
9C1Driver is on a distinguished road
Default
The 122xl and Grant xl are nice radio's for what they are and do. You will never make one talk on AM like a Stryker though. I would try to make it be all it can and then leave well enough alone.
  #4 (permalink)
Old 10-17-2008, 05:49 PM
Switch Kit's Avatar
Senior Member
Switch Kit is on a distinguished road
Default
PC-122s are loud from the get go . You want louder ? Use a D-104 hand held. When someone says they want a louder PC-122 , I'd think you had a lemon or something. Good luck.
  #5 (permalink)
Old 10-22-2008, 06:03 AM
Bow's Avatar
Bow Bow is offline
Junior Member
Default
Thanks for the replies gents,
Thanks Moleculo, those are the "handy Andy" mods I mentioned. I've completed those.
Switch:
it isn't just about "Louder Audio", it is about more audio with quality audio. Like 150% positive modulation and limited to 99% Negative modulation.
  #6 (permalink)
Old 10-23-2008, 05:57 PM
Senior Member
Default
I bet that looks great on a scope, That guy 10 channels away can hear you too.
  #7 (permalink)
Old 10-30-2008, 10:05 PM
Switch Kit's Avatar
Senior Member
Default
I didn't catch that one. No such thing as 150% audio . It's either 100% scoped out or over the hills and far away. That's all good with me. NPC / Swing / Diode / jump'in this and that and it all adds up to the same thing.
I said the PC-122s were pretty darn good loud radio out of the box with a slight tune , I have nothing against all the wham whams and zoo zoo's a guy can do to his radio to make it do this or that. To each his own.
There's a lot of radio there in a small chassie. Although they are no 148/Grant , they can hold there own for what they are.
PC-122s are decent small chassied AM/SSB'er's . Experiance has taught me (especially on these radios) to much is to much. They will run hot and eventually fail when they didn't need to. Those radios set at 100% are LOUD ! Run a box ? 2 to 8 would get job done nice at the 100% , they will do 20 on SSB ,but running a box ? one might drop the carrier down a little for a cooler running radio in the long and short of it.
Your NPC type mod will work as far as running the box goes on AM , but the audio chip and voltage regulator on those radio run side by side and they will get hot to the point of burning you and up , those audio chips ain't cheap either (if you can find them) like I said before , best to take it easy on those radios , there decent and will stay that way while being treated nicely.
  #8 (permalink)
Old 11-06-2008, 08:50 AM
Bow's Avatar
Bow Bow is offline
Junior Member
Default
Quote:
Not true.
Overmodulation on the Negative causes the splatter.
AM broadcast stations can legally run up to 125% positive and 100% Negative modulation.
If you overmodulate in the negative direction, you splatter... if you can keep the negative at 100% of slightly less, you can run more positive modulation, hence louder, clean audio.
The reason I am using a PC122XL is because I have one here... and I don't use it
Also, the PC122XL doesn't use a modulation transformer, so I can run more audio bandwidth without the transformer limiting it
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
