WorldwideDX Amateur Radio Forums
WorldwideDX Amateur Radio Forums (http://www.worldwidedx.com/forums.php)
-   CB Band and CB Radios (http://www.worldwidedx.com/cb-band-cb-radios/)
-   -   Cobra 2000gtl Audio mods. (http://www.worldwidedx.com/cb-band-cb-radios/30792-cobra-2000gtl-audio-mods.html)
GunSlinger338 10-28-2008 10:52 AM
I recently picked up a Cobra2000 GTL..Brand New in the BOX !! . going to use it primarily for local every day talking..
Would like to get it capable of transmitting better quality audio on AM ...
Any one know any Mods. to widen the transmit audio range????????
Moleculo 10-28-2008 05:48 PM
There was a thread here, but I couldn't find it. This was posted a while back as a complete set of mods for audio:
Also applies to:
Cobra 148GTLF
Cobra 2000GTL
Undien Grant XL
Uniden Grant LT
1. Carrier Adjustment: VR10. If lower carrier is desired, change R196 near VR-10. Try about 270 ohms.
2. Change R114 to a 10K, and C46 to a .2 monolithic, this will widen up the audio on AM.
3. The AMC is TR-26. You can remove it, and still have good results on AM, the ALC for SSB is not effected by this. If you don't want the AMC disabled, leave it. The other way to disable the AMC is cut R131. Check both to restore AMC from previous mods.
4. If extra frequencies have been added, perform the following to widen up the band pass filters to recover lost power at the highest and lowest frequencies: C163 - 4pf, C41 - 3pf
5. R180 - Jumper it. This brings up the gain of the TX mixer.
6. IC TDA6130 - Pin 12 to ground through 100 ohm resistor. Upper left, pin 14 = ground.
7. Remove the AM regulator, (usually a 2SC1419) and replace it with a 2N6487.
8. C174 - remove, add 1000uf electrolytic. connect POS to base of yellow wire next to it. If the yellow wire is too far away, it might be easier to connect the POS leg to the leg of the AM regulator closes to the back of the chassis via the bottom of the radio.
9. For 148F, change C18 to a 1000uf electrolytic, 16V
GunSlinger338 10-29-2008 05:49 AM
Thanks....... I too was unable to find it in other posts
KB1TPX 10-29-2008 03:36 PM
CB Tips and Tricks:thumbup:
Number15 10-29-2008 05:32 PM
Hey gunslinger how much did u pay for that 2000??????
super20dan 10-30-2008 05:14 AM
only and idiot would mod this mint radio-why do you think ebay is loaded with broken 2000 cobras
GunSlinger338 10-30-2008 06:16 AM
Quote:
400$ and some change
KB1TPX 10-30-2008 06:52 AM
Wrong one, ...this one is better.
The Defpom Cobra Mods and Tuning List
Powered by vBulletin®
Worldwide Radio Forum
