Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 10-28-2008, 11:52 AM
GunSlinger338 is on a distinguished road
Default Cobra 2000gtl Audio mods.
I recently picked up a Cobra2000 GTL..Brand New in the BOX !! . going to use it primarily for local every day talking..
Would like to get it capable of transmitting better quality audio on AM ...
Any one know any Mods. to widen the transmit audio range????????
  #2 (permalink)
Old 10-28-2008, 06:48 PM
Senior Member
moleculo has disabled reputation
Default
There was a thread here, but I couldn't find it. This was posted a while back as a complete set of mods for audio:
Also applies to:
Cobra 148GTLF
Cobra 2000GTL
Undien Grant XL
Uniden Grant LT
1. Carrier Adjustment: VR10. If lower carrier is desired, change R196 near VR-10. Try about 270 ohms.
2. Change R114 to a 10K, and C46 to a .2 monolithic, this will widen up the audio on AM.
3. The AMC is TR-26. You can remove it, and still have good results on AM, the ALC for SSB is not effected by this. If you don't want the AMC disabled, leave it. The other way to disable the AMC is cut R131. Check both to restore AMC from previous mods.
4. If extra frequencies have been added, perform the following to widen up the band pass filters to recover lost power at the highest and lowest frequencies: C163 - 4pf, C41 - 3pf
5. R180 - Jumper it. This brings up the gain of the TX mixer.
6. IC TDA6130 - Pin 12 to ground through 100 ohm resistor. Upper left, pin 14 = ground.
7. Remove the AM regulator, (usually a 2SC1419) and replace it with a 2N6487.
8. C174 - remove, add 1000uf electrolytic. connect POS to base of yellow wire next to it. If the yellow wire is too far away, it might be easier to connect the POS leg to the leg of the AM regulator closes to the back of the chassis via the bottom of the radio.
9. For 148F, change C18 to a 1000uf electrolytic, 16V
  #3 (permalink)
Old 10-29-2008, 06:49 AM
Default
Thanks....... I too was unable to find it in other posts
  #4 (permalink)
Old 10-29-2008, 04:36 PM
7732granitestate's Avatar
7732granitestate is on a distinguished road
Thumbs up
CB Tips and Tricks
__________________
Cobra 139, "The Bishop" preamp, JoGunn antenna/transmitter tuner, Memtrix MX-41A freq. counter, Radio Shack SWR/power meter, Para Dynamics PDC1089 low pass filter, Home Brew vertical dipole.
"The more educated you become, the more dangerously you live."
  #5 (permalink)
Old 10-29-2008, 06:32 PM
Supporting Member
Number15 is on a distinguished road
Talking
Hey gunslinger how much did u pay for that 2000??????
__________________
  #6 (permalink)
Old 10-30-2008, 06:14 AM
Junior Member
super20dan is on a distinguished road
Default
only and idiot would mod this mint radio-why do you think ebay is loaded with broken 2000 cobras
  #7 (permalink)
Old 10-30-2008, 07:16 AM
Default
Quote:
400$ and some change
  #8 (permalink)
Old 10-30-2008, 07:52 AM
Default
Wrong one, ...this one is better.
The Defpom Cobra Mods and Tuning List
__________________
  #9 (permalink)
Old 10-30-2008, 02:38 PM
Default
Quote:
LOL.... this must be the guy that was out bid at the last sec.
Sorry Guy
  #10 (permalink)
Old 10-30-2008, 06:04 PM
Senior Member
9C1Driver is on a distinguished road
Default
With such a nice, origional mint radio I would have a qualified tech go through it. A nice tune and alignment should do the trick. Combine that with a D104 desk mic and you will be wall to wall.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
