Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 11-06-2008, 02:11 PM
Junior Member
rev1970 is on a distinguished road
Default roger beep
Has any one ever put one in side a mic i have a hr2600 with a desk mic and want a beep but don't want it in the radio i have room in the mic to put it just need to know if it can be done ???
  #2 (permalink)
Old 11-06-2008, 09:28 PM
Senior Member
bigred222 is on a distinguished road
Default
they make microphones with roger beeps
http://www.cbradiosplus.com/shop/pc/...&idproduct=825
i wish i could help more. not to expensive for that mic either 15 bucks.
__________________
Galaxy DX22B
Galaxy DX2547
Courier Bl-100
Antron 99
Cobra 139xlr
Cobra 142gtl
Cobra 29xlr Cant beat this radio.
ADX-202
CDX-202
  #3 (permalink)
Old 11-07-2008, 06:59 AM
Junior Member
Default
That is cheap i was just asking because i like the desk mic that i have now and have the roger beep board so i was looking to see if it could be done..
  #4 (permalink)
Old 11-07-2008, 04:46 PM
Junior Member
packrat is on a distinguished road
Question
Just a thought. could you buy the 15.00 mic with the roger beep and transplant its guts into a desk mic body?
  #5 (permalink)
Old 11-25-2008, 01:14 PM
Junior Member
Default
no one has ever tried this
  #6 (permalink)
Old 11-26-2008, 09:45 AM
Senior Member
949Jake is an unknown quantity at this point
Default
Well I'm sure someone has tried it...
__________________
"IT'S A SEARS ROADTALKER WORLD"
  #7 (permalink)
Old 11-26-2008, 12:20 PM
WR0220 is on a distinguished road
Default
Anything is possible...
I don't know what brand roger beep you have, but most I have seen have 5 wires:
Power
Ground
Audio
Transmit x2
Power & Ground are obvious. Solder the Audio wire of the RB to the Audio wire of the mic cord inside the mic base. The TX portion of the RB goes in series - remove the TX wire inside the mic and solder to one of the TX wires of the RB (refer to instructions for proper wire) then solder the other TX wire of the RB to where you removed the original TX wire. You'll probably go through batteries quickly with the added draw, so you may want to consider adapting a wall wart instead. If you wanted to add an on/off switch place it in series with the Audio wire on the RB module.
  #8 (permalink)
Old 12-27-2008, 12:49 PM
Junior Member
Default
thanks i do have a 5 wire and i will try it that way i might try it tonight every one has been telling me it can't be done and i don't see way not your going to tap into the same wire's in side the radio except for the power i think it takes 8.5 but i could be wrong so thanks for the help again ...........REV
  #9 (permalink)
Old 01-03-2009, 01:45 PM
Junior Member
cobranut is on a distinguished road
Default
A little bit of trivia. How many of you know what the Roger beep was originally used for?
__________________
100% disabled veteran, RSVN -'68/'69 TET
  #10 (permalink)
Old 01-03-2009, 08:52 PM
MisterFatty is on a distinguished road
Default
IIRC NASA
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
