Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
I have a Realistic TRC-482 and was wondering...
Reply
  #1
Old 12-08-2008, 06:07 AM
Junior Member
The_Redneck_Man is on a distinguished road
Default I have a Realistic TRC-482 and was wondering...
Why when I first installed it into my car and I have a K2 antenna I think that is what type of antenna it is, not exactly sure. It's a 40 channel radio with WX 3 channels. I noticed after I installed it into my car, this was in a warm garage. It's a 7 footer too.
Then after it got real cold I noticed that the 4 lights for the tx and rx power lights when I am transmitting it goes one light when I push it down it and then it flickers to 2 lights and then goes back to one light after it is pushed all the way down, also sometimes when I talk into it it sometimes will flicker to 2 lights again but only for split second. It was fine when I first installed it in the garage? Please help me I would greatly appreciate it!
  #2
Old 12-09-2008, 04:40 AM
Junior Member
Default
Hello can someone help me please it would be greatly appreciated thats for sure! Thanks
  #3
Old 12-09-2008, 05:23 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
if the vswr of the antenna is good and its not affecting what your transmission or recieve i wouldnt worry about it . it seems cosmetic . i would GUESS the led's are going bad or a dirty key on the mic .
  #4
Old 12-09-2008, 05:28 AM
Junior Member
Default
Quote:
Yeah it seems to send and recieve fine and the mic is the original mic that came with it and it is dirty. I haven't tested long distance though just 50 or 100ft or so. Thanks a lot an also I am wondering what the NB button that is on it does?
  #5
Old 12-09-2008, 10:13 AM
Moleculo has disabled reputation
Default
NB is Noise Blanker. It helps cut out ignition noise or other motor noise that can into the RX of the radio.
  #6
Old 12-09-2008, 04:45 PM
Junior Member
Default
Ok thanks a lot now I know and I greatly appreciate it that's for sure!
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
