Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Ssb audio distorted when using amplifier
Reply
  #9
Old 02-13-2009, 11:18 AM
EDUK8TR's Avatar
EDUK8TR is on a distinguished road
Default
Quote:
Originally Posted by TonyV225 View Post
Could be RF feeding back into audio section dirty amplifer but more info would help class of amp A/B biased?
Ok. If the amp has a SSB switch it is probably biased for that mode. I'm kinda with Tony up to this point. Sounds like an RF feedback issue which could be remedied with some proper grounding and a check on how good a ground you have on the antenna install. I had the same issue once in a previous mobile install and the extra grounding took care of the issue.
__________________
"To be is to do"-Socrates;
"To do is to be"-Sartre;
"Do Be Do Be Do"-Sinatra;
WV4L,CDX-787,AK2787
Mobile/Base
Icom70000/Kenwood TS-2000 w/LDG AT-1000ProII
Stock mic or W2ENY headset on VOX/D104 w/Heil HC-5 or W2ENY headset on VOX
Tarheel 200A-HP w/N2VZ Turbo Tuner,Larson NMO 2/70B/TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP
Ameritron AL80A
  #10
Old 02-13-2009, 11:27 AM
Damo666 is on a distinguished road
Default
Quote:
the audio is perfect on fm and am with the amp, and it's also good on ssb without the amp switched on. I use a 1/2 wave basic vertical. Suggestions as to grounding my system would be appreciated. Would joining a wire from the bracket of my antenna into the garden help do you think? I'm willing to give anything a try to eliminate this problem. Cheers again.
  #11
Old 02-13-2009, 11:57 AM
Moleculo has disabled reputation
Default
First, let me preface this by saying that I'm not that great at reading schematics...
...but I just looked at the schematic for that amp and it looks like a class C amp to me. It's using FETs and I'm not very familiar with amplifier design with them. Perhaps someone else can look at the schematic who is better than me. The SSB switch on the schematic is clearly just switching a capacitor inline with the relay to keep the relay from chattering in SSB mode.
If it's a class C amp, you're going to have this problem on ssb. You still didn't say what radio you're using.
  #12
Old 02-13-2009, 02:20 PM
Default
cheers for the reply. I also noticed that all the ssb switch does is switch in a cap. I'm using a Superstar 3900 turned down to 4 watts on fm/4 watts pep on ssb. Can anybody else confirm that this amp is unsuitable by viewing the schematic please? Cheers.
  #13
Old 02-13-2009, 02:27 PM
Senior Member
9C1Driver is on a distinguished road
Default
Is this a base or mobile? How are both units being powered? Running both on too small a power supply or the amp on small feed wire and a week battery can cause what you are seeing.
  #14
Old 02-13-2009, 03:22 PM
Default
Quote:
I'm base. I'm running the radio and burner from the same battery. And the power cable is rated at 10 amps. I'm beginning to think that the amp circuitry isn't designed for ssb, even though a ssb switch is on the unit. Have you had a look at the schematic?
  #15
Old 02-13-2009, 05:10 PM
Senior Member
Default
I think you are drawing too much from the battery when the amp is in-line and turned on. If you starve an amplifier it will sound like crap. Buy a decent power supply and go that route. My money says thats your problem. I did a google search on your zetig amplifier, it has a SSB delay so it will work on SSB.
  #16
Old 02-14-2009, 12:07 AM
Default
Common CB myth: "my amp has a SSB delay, so it will work on SSB". No. The SSB delay on most of these amps is simply a capacitor that is switched in with the relay that prevents the relay from chattering because there is no carrier to keep the relay engaged between voice peaks. That alone does not make it suitable for SSB. For SSB, it's important that linearity is maintained which is nearly impossible with a class c amplfier inline.
I compared the schematic with one I found on the web for class c mosfet rf amplifier and the relevant sections look pretty much the same. I also looked at a schematic of an AB biased mosfet amp. Please understand that I'm not very versed with MOSFET PA design so I could be very wrong, but I can't see how that amp you have is much different than the class C design I found. It is possible that you have other issues like drawing too more current from a battery than it is capable of, but I doubt it. FM and AM modes typically draw more current than SSB does and you're not having problems with anything other than SSB. Everything you're saying points to a non-linear amplifier which should not be used on SSB. Sorry to be the bearer of bad news.
Reply
Bookmarks
Tags
ssb distortion
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
