Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 25 ERF2030 Upgrade
Reply
  #1
Old 02-14-2009, 08:22 PM
Junior Member
fsjonsey is on a distinguished road
Default Cobra 25 ERF2030 Upgrade
Hello Everyone!
I just finished installing the ERF2030 MOSFET upgrade in a Cobra 25. It works, but the problem is, I'm only seeming to get a 1 watt dead key, and about 4 watts swing into a dummy load with the mic gain maxed. I followed the instructions on cbtricks.com to the letter. Shouldn't I be seeing more power? Is this common?
Could the Bias on the 2030 be incorrect?
I appreciate any advice. This is really leaving me scratching my head.
Thanks in Advance,
-Bryan.
  #2
Old 02-14-2009, 09:27 PM
Flying Dutchman's Avatar
27.275 Operator
Flying Dutchman is on a distinguished road
Default
vr2 is the power on that radio if i am not mistaken, try turning that up a bit. and the modulation pot to 100%
__________________
Northern California
  #3
Old 02-14-2009, 09:47 PM
Junior Member
Default
Quote:
I already adjusted the AM Power and Modulation pots. Four watts is the most I've been able to get out of this radio with the ERF2030 installed. Is there anything else I could be missing?
  #4
Old 02-15-2009, 01:25 PM
Junior Member
Default
Sorry to keep bugging you guys, but I just checked the Bias voltage on the gate of the ERF2030, and I'm only getting about 1.3v at transmit. Is there a way to adjust the bias voltage so that it is closer to the recommended 2.7v?
  #5
Old 02-15-2009, 02:24 PM
WorldWide MudDuck
TruckDrvr46201 is on a distinguished road
Default
Quote:
Did u Double Check that u changed all Resistors and Caps to the proper values if i remember correctly there is something about C62 in that mod... Double Check it and make sure everything is working sounds to me like u might have missed some little detail i have only done 2 of these myself and never ran into this ...
__________________
Breaker Breaker theres a Picture Taker Ol Smokies at 43
Radios
Cobra 29 LTD-ST (Modded out) Skythumper ST65DX Lotsa Power Toys, Gator Stick, Copper 8 Coil
Cobra 2010GTL Modded Out, D104, A99-GPK1
TR696-FD1 (Baddest Radio on the Block for the $$$) Dual Mosfet Conversion, Channels,Tied, Texas Star 667v Capped out, Wilson 5000 (my Pickup) woooooo
  #6
Old 02-15-2009, 02:53 PM
Junior Member
Default
Quote:
Everything is installed as it should be. I removed the final, R38, R40, C45, and the slug from L10. I installed the MOSFET, the 1230 companion part (polarity observed), and the 68pf cap across C42. Still, I'm only deadkeying about 1 watt and swinging to 3.5.
  #7
Old 02-15-2009, 04:12 PM
Warbird's Avatar
Warbird is on a distinguished road
Default
It sounds like you have answered your own question, you need to add more bias voltage. What I do is find a 12v source, put a 100K (because that's what I have) variable resistor from the 12v source to the gate, adjust until you get the voltage you are looking for, remove the variable and test for resistance and replace with the proper resistor... or leave the variable. I shoot for more in the range of 3.5v and you should get 4 watts (plus) dead key and good forward power on modulation. If your voltage is too high... it'll swing backward on you, if it's too low, you get low dead key.
  #8
Old 02-15-2009, 04:30 PM
WorldWide MudDuck
Default
something else is that an OLDER 25 or a NEWER 25 if its the OLDER 25 Remove the 68pf cap and put the slug back in L10
__________________
Radios
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
