Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Golden Eagle "Key-up "
Reply
  #1
Old 04-11-2009, 07:22 PM
Lik2race's Avatar
Tube Radio Junkie
Lik2race is on a distinguished road
Question Golden Eagle "Key-up "
Does anyone know if there is a way to lengthen or shorten the "key-up", on the
Browning Golden Eagle. ??
__________________
Stan aka Lik2race
[IMG][/IMG]
Worldwide Radio Forum
  #2
Old 04-11-2009, 08:48 PM
Senior Member
moleculo has disabled reputation
Default
Probably just change a cap in the key up circuit. Do you have a schematic of the section that produces the key up sound?
  #3
Old 04-12-2009, 05:41 AM
Senior Member
linearone is an unknown quantity at this point
Default
adjust the mic gain and squelch to suit.
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
  #4
Old 04-12-2009, 01:17 PM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
Adjust the key up? Do you mean the length of the "squeal"? You will have to change the value of a capacitor in the receiver to shorten it....probably 20 to 40 mfd at 450 volts, the smaller the cap the shorter the squeal.
BC
__________________
BC
  #5
Old 04-12-2009, 01:41 PM
Senior Member
Default
If it is the squeal you want to shorten here is how to do it.
In the receiver locate V10, the 6AQ5 tube right behind the speaker. From under the chassis locate pin 6 which has a red wire tied to it. Follow this red wire to the nearby terminal strip to where it is connected to a 2.2K 1/2 watt resistor (red, red, red). You won't want to go smaller than a 20 mfd cap at 450 volts with the positive lead going to the 2.2K and negative lead going to ground. Anything 80 mfd or above will produce a long squeal and place undo strain on the relay and other components. Usually 35-47 mfd makes a nice squeal.
One other thing...if a cap is installed in this place already you will need to remove it.
BC
__________________
BC
  #6
Old 04-12-2009, 02:07 PM
Robb's Avatar
WWRF Moderator
Robb is on a distinguished road
Default
I know that YamahaDude (member on this forum) has a Uniden Madison that has a button on it that emulates the 'squeal' or 'ping' for the Golden Eagle.
So moleculo is probably right. There must be a cap that can be changed to shorten that key-up squeal. In much the same way that one can change the character tone and length of a roger beep in any radio.
I have never read anything on this problem of this 'feature' of the Golden Eagle to change or correct it - anywhere. Probably exists in a Sam's publication. Maybe...
But remember - that 'squeal' is a signature of that radio. I know two guys in my area that have them and use them. They won't change that feature and they are going to keep it in place. It is a part of that radios character - I guess...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...World Radio One-One Northern CAL - Standing By..."
  #7
Old 04-15-2009, 05:09 AM
Senior Member
Default
Did you get the Browning fixed to the way you want it? Just wondering. They are great radios.
__________________
BC
  #8
Old 04-15-2009, 06:22 PM
Senior Member
Default
I got in the noise toy that's supposed to sound like the Browning Eagle key up scream: http://www.worldwidedx.com/noisetoys...agleScream.wav
The person that originally wanted it changed their mind, so I still have it. I can't remember when I heard an actual Browning Eagle last, so I don't really remember how close this noise toy sound is to the real thing?
  #9
Old 04-15-2009, 06:39 PM
Robb's Avatar
WWRF Moderator
Default
The way the Browning Golden Eagle sounds when it keys up?
It is the sound of the D104 feeding back for a moment - and then stopping.
Both of the Golden Eagles around my neck of the woods sound like that. I asked both of these guys to adjust it so it wouldn't make that feedback squeal, and both of them said that it is just how the radio sounds - and cannot be adjusted or stopped.
?? Go figure ??
__________________
What gear do I use?
  #10
Old 04-15-2009, 07:48 PM
unit_399's Avatar
BIGSTRAPPER
unit_399 is on a distinguished road
Default
Bionic Chicken's post is exactly correct as to the modification. If you have an early model Mark III made prior to Feb 1977, than the stock capacitor (C66) will be 20 uf @450 volts. The discharge time of this cap caused the receiver's speaker output to remain on for several milliseconds when the transmitter was keyed up and the resulting feedback caused the unit to "ping" or squeal. In Feb '77 the FCC made Browning eliminate the "ping" so C66 was changed to a 2 uf @ 450Volts for late model Mark IIIs. Several Eagles that I worked on had C66 removed and a 3 position switch installed on the receiver's rear skirt, which allowed either a 2 uf, 20 uf, or 40 uf cap to be switched in to change the length of the ping. As BC said, exceeding 40 uf is really tough on some of the components, and is not recommended.
- 399
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
