Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 29 LTD Classic Problems : Weak Receive, No Transmit
Reply
  #1
Old 06-08-2009, 03:46 PM
Senior Member
office888 is on a distinguished road
Default Cobra 29 LTD Classic Problems : Weak Receive, No Transmit
Hello,
I'm pretty not new to CB radios, but I am new to fixing them.
I got a Cobra 29 LTD Classic off of a friend of mine. It powered up okay, the display only works on bright, but I didn't think it was a huge problem.
I tested it a spare antenna and with my existing car rig (Cobra 19 + Wilson Antenna). The Cobra 29 receives very poorly. Sound is very weak and full of static when I key. Even with squelch all the way off, and gain all the way up, I still can't get the speaker to produce any regular static.
Transmit is another story. When I key, I hear the pop of the key activating and my Cobra 19 goes silent like someone is transmitting, but it won't transmit any of my voice.
Help?
Thanks,
Richard
  #2
Old 06-09-2009, 09:33 AM
Moleculo has disabled reputation
Default
Sounds like it could be the audio chip. Can you test the PA function?
  #3
Old 06-09-2009, 03:22 PM
Senior Member
Default
Quote:
Just tested it, no output at all.
Bad audio chip then?
"NPC 9222
D2816C" - the audio chip?
Also, would it interfere with anything if I removed the internal speaker and replaced it with a small 12V-switched fan? I wanna peak&tune this unit to get a bit more "umph" out of it. I've been into computers for a while, and I know heat is the bane of electronics.
It's going to go in my 90' Audi 80 "Wintertastic Rallybeater" with a Wilson-1000 probably.
-Richard-
  #4
Old 06-09-2009, 03:36 PM
Senior Member
Default
One other thing, the onboard meter does not work at all. Not sure if that affects anything?
-Richard-
  #5
Old 06-09-2009, 05:27 PM
Default
"NPC 9222
-Richard-
No, it's IC4 - TA7222AP or something similar. You don't need the fan anyway if you're going to peak it out - even if you do a more extreme mod like a 50 watt FET. The final transistor is mounted to what is effectively a big heat sink. If you really want to add a fan, you could wire it to 12v and mount it on the back/top, but run the power leads through a small ferrite torroid a few times. If you don't you'll get nasty motor whine in the TX/RX.
  #6
Old 06-09-2009, 05:29 PM
Default
-Richard-
Fix the audio amp first, then try the meter. It could be out or just stuck. If it's stuck, carefully lift up the tape on the top of the meter, apply a tiny drop of oil on the screw and turn it carefully a little bit. If it still doesn't work, you'll need a new meter - they aren't expensive.
  #7
Old 06-09-2009, 07:00 PM
Senior Member
Default
That took a bit of searching, weird hiding spot on the side...
Surrounding the TA7222AP is a bunch of white powdery crap. Solder joints are more "hilly" than the rest. Looks like it might have been replaced before?
Regardless, $5.25 part, going to go ahead and replace it anyways.
No fan it is then!
Thanks for the help, we'll see if that's the issue.
-Richard-
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
