Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Using Realistic 5 pin mic with Uniden Pro510xl 4 pin connection?
Reply
  #1
Old 06-12-2009, 10:11 PM
Repo Man
Blaine B. is on a distinguished road
Question Using Realistic 5 pin mic with Uniden Pro510xl 4 pin connection?
Hi there. The microphone that worked with my Uniden Pro510XL CB radio recently quit working. The microphone that quit working as well as the radio connection are a 4 pin setup.
I have a Realistic (Radio Shack) microphone here that is a 5 pin setup.
I snipped the ends off of both radios and was going to solder on the Uniden 4 pin plug to the Realistic mic.
I read up and found that this is possible to do as long as you do not hook up the ground from the Realistic mic, which is the 5th wire.
However the wire colors between the two microphones are completely different and I was wondering if anybody could help me to determine which wire is what?
I am probably messing with this a bit late as there is an offroading trip Saturday evening which I need this to work for. I should probably just go buy a new microphone from the truck stop but if this can work I figure I mind as well do this "conversion" and save a few bucks.
Thanks a bunch!!
  #2
Old 06-12-2009, 11:21 PM
Repo Man
Default
FYI, the wires with the Realistic microphone are white wrapped with an insulator/isolator, red, black, and blue.
The wires with the Uniden microphone are blue wrapped with an insulator/isolator, grey, and brown.
The Uniden plug is marked 1, 2, 3, and 4.
If anybody could point me in the right direction, that would be much appreciated.....thanks!
  #3
Old 06-14-2009, 08:34 AM
Wheeling on the trails
1997ZJ is on a distinguished road
Default
These links might be of some use to you...or not. I tried.
CB Radio Microphone Wiring | THUNDERPOLE
Mic Wiring Pinouts and instructions by dxzone.com
Mike wiring guide by dxzone.com
On the last two links, just click the first link in the main body of the page for the actual document I was trying to link. The last link might be most useful considering it will walk you through identifying the proper wires for each function.
Finding a wiring diagram for your Uniden will be simple and painless...finding one for the radioshack mic is going to be difficult.
  #4
Old 06-14-2009, 01:52 PM
Repo Man
Default
Thanks, I'll take a look at your links in a bit. I was able to borrow a mic to use for last night's event so all was well.
I did some searching the night before and it was really confusing because different websites listed different wire colors for the same radio and mic...
  #5
Old 06-14-2009, 05:07 PM
Repo Man
Default
I think I have the correct information here now, thanks to your links.
For the RadioShack/Realistic mic, it appears the blue wire is just there for kicks and is not used. White is the mic audio, black is receive, red is transmit, and then you have the shield.
From the solder side of the Uniden 4 pin plug, it appears that 1 is common, 2 is mic audio, 3 is receive, and 4 is transmit.
I will wire it up like so in a bit and see if it works out!
Although I also see that Cobra mics have pin 1 being mic audio, pin 2 being common, and pins 3 and 4 being the same as the Uniden mic.
But I have been able to use a Cobra mic without problems.....so I'm confused! At least transmit and receive are the same, if it still doesn't work I suppose I could just swap wires from pins 1 and 2 and either way it should work then for sure..................
  #6
Old 06-14-2009, 07:06 PM
Repo Man
Default
Got the Realistic mic wired up to the Uniden plug and working correctly!
Their information regarding how Cobra mics had the mic audio and common mismatched. Cobra mics work on my CB so I just wired it up like that. The receive and transmit wires were correct though. At least it works!
  #7
Old 06-14-2009, 09:09 PM
Thumbs up
Hey! Glad to hear it!
Good work on fixing it up!
  #8
Old 06-14-2009, 09:34 PM
Repo Man
Default
Thanks and thanks for the links!
BTW you have a 97 ZJ? I have a 95 XJ.....7" on 33's....
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-band-cb-radios/34581-using-realistic-5-pin-mic-uniden-pro510xl-4-pin-connection.html
Posted By For Type Date Hits
realistic cb radio This thread Refback 01-21-2010 07:27 AM 4
Powered by vBulletin®
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
