Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 29 XLR budget build.
Reply
  #1
Old 07-02-2009, 05:16 PM
Junior Member
Double T is on a distinguished road
Default Cobra 29 XLR budget build.
Hi, I want to add some stuff to my 29 XLR. I want to add talkback, better recieve range, & a little more power. How would i go about doing that?
Worldwide Radio Forum
  #2
Old 07-02-2009, 06:29 PM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
Why talkback in a radio without echo? If you want more power, buy a 100 watt amp.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
  #3
Old 07-02-2009, 06:46 PM
Junior Member
killapits is on a distinguished road
Default
you could use a rfx75 for more power
  #4
Old 07-02-2009, 07:25 PM
Senior Member
9C1Driver is on a distinguished road
Default
I would send it to a decent radio shop and have them peak and tune it properly. They will have several options for you to choose from. Here are some decent places right off the top of my head in no order.
1) DTB Radio
2) Sparky's cb
3) Custom cb Radio
4) Bob's cb
5) 8541 Electronics
Just do a google search for each and a web page should be there at or near the top.
  #6
Old 07-02-2009, 08:54 PM
Junior Member
Default
Quote:
I dont have the money for an amp & i'm running a DM 452 power/echo mic.
  #7
Old 07-03-2009, 08:50 AM
psycho's Avatar
Senior Member
Default
Unless the receive is off a mod like that is a waste of money. You can search the web and find peak and tune info from several different sites. Talkback is a simple procedure and someone here should be able to give you info on that.
__________________
  #8
Old 07-03-2009, 11:59 AM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
what type of antenna are you using and how is it mounted ?
you antenna system can/will make more difference than any modification .
i agree with psycho about adding a seperate amp for more power rather than modifying the radio for more power .
__________________
  #9
Old 07-03-2009, 12:18 PM
Senior Member
Default
this is a cheap and easy way to add variable talkback to a cobra or uniden radio .
Univeral Talkback Controller **NICE**
i just got one to try on my uniden 78 , it does what it says .
__________________
  #10
Old 07-03-2009, 05:28 PM
psycho's Avatar
Senior Member
Default
That is a pretty neat item....take the variable talkback with you from radio to radio.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
