Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
CB setup
Reply
  #1
Old 07-03-2009, 12:26 PM
dmag's Avatar
Junior Member
dmag is on a distinguished road
Default CB setup
How do you set up your CB:
with the SQL turned all the way left and control it with the RF Gain
or with the RF turned all the way right and control it with the SQL
I was told SQL left NB/ANL off and control with RF
I don't see much diff. ?
Worldwide Radio Forum
  #2
Old 07-03-2009, 01:03 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Woof!
Use the NB/ANL to cut out static in your receive to your liking. Same goes for sqelch. Turn up the squelch until it shuts off the sound. Are you using a Cobra 29LTD or similar? More info needed...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9...no linear power
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770...no linear power
  #3
Old 07-03-2009, 04:10 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
If you have reason to use the NB/ANL, then use it. If you haven't a reason, then don't. Just depends on the noise you're trying to get rid of.
RF gain. Personally, I like it all the way UP. That tends to make the weak ones easier to hear. It also increases noise. So, if you don't wanna listen to the noise in the background with no signal, use the SQL to stop it. Noise levels change, so that SQL will change, the setting varies with the noise. The SQL does NOT do the same thing as the RF gain control does. That RF gain controls sensitivity. The SQL, in effect, just turns off the speaker so a stronger signal has to be present before you hear anything. If you decrease sensitivity, that 'stronger signal' has to really be stronger to be heard. Think of it like decreasing the sensitivity in your fingers. At some point they get numb. You won't know you're being cooked till you smell stuff burning, you know?
The whole idea is to make things comfortable to listen to without a lot of 'extra' noise. Adjust to suit your self. That's what's 'best' for you.
  #4
Old 07-03-2009, 06:32 PM
dmag's Avatar
Junior Member
Default
I am running a cobra 29 LTDI usually run the noise limiter in the middle at ANL. I have tried it with RF gain maximum and the squelch turned up to stop the noise. Somewhere around 11 o'clock, and I have ran it with the squelch wide open, and used the RF to turn down the noise. Some where around one o'clock. I guess there's just no set it and forget it situation
  #5
Old 07-04-2009, 01:33 PM
Senior Member
SR385 is on a distinguished road
Default
It's expensive for budget CB use, but if any of you want to try something that will just crush the band noise, look at the BHI ANEM module. It is so good with the adaptive DSP it has that I run 2m FM simplex without squelch when working distant stations...it knocks the band noise out THAT much.
It is worth every cent....doesn't kill impulse noise, but it kills band noise/hash dead.
NEDSP-1062-KBD
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
