Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
More power in a Cobra
Reply
  #1
Old 07-09-2009, 01:49 PM
Oldtimer's Avatar
Senior Member
Oldtimer is on a distinguished road
Default More power in a Cobra
Is there a way to get more watts from a Cobra 25 LTD Classic without
adding any parts?
Thanks
__________________
My Toys
Galaxy DX 95T2
Galaxy DX 929
Uniden PC66XL
Connex 3300
2-Cobra 25 LTD Classics
KLV 550
Pyramid PS-26 KX
Imax 2000
GOD BLESS
  #2
Old 07-09-2009, 02:19 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Sure - get a 100 watt linear.
Other than that - don't expect power gains out of a radio that is built to conform to FCC specifications. If tweaked and peaked properly with the stock parts on board, one can only expect a couple of extra and dirty watts. It is better to have it turned DOWN a little bit - and then add a 100 kicker. Or more. I prefer the 100 watt - btw...
I have a friend of mine that hs a modded ('parts added') 25LTD. It S C R E A M S ! ! !
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 07-09-2009, 05:19 PM
Senior Member
9C1Driver is on a distinguished road
Default
The overall audio quality, receive, and general performance can be improved over stock. Remember, a stock radio is "ballparked" in on the assembly line. A complete alignment of the radio is a must. Beyond that there are many other options as far as swing kits, audio kits, and final swaps. If you want substantial power improvement an amplifier would be the best choice. A proper tune is still needed though to set the carrier right for the amplifier you get.
  #4
Old 07-11-2009, 08:31 PM
Junior Member
tsquared is on a distinguished road
Default
What type of antenna are you using ?
The old saw of cheapest radio/best antenna holds true.
  #5
Old 07-12-2009, 08:25 PM
secret squirrel's Avatar
Lustrous Potentate
secret squirrel is on a distinguished road
Default
9C1Driver has it right. Proper tune and alignment and a quality microphone will work great. I had a stock radio I used out of the box for years. I always thought it talked great. After I had it peaked and tuned it was like it was a new radio. The local guy that tuned it said it was way off frequency with little modulation. It was my first CB and old Uniden 510XL. Our local tech said it was 2 watt DK with swing to 7 watts. The peak and tune puts it at 5 watts swinging to 21 watts. I was a little sceptical, because I had used it for years so I had Bob F. of Bob's CB I-80, PA check it for me when I was in the area. Bob put it on his bench and his only reply wa nothing needs done- someone already tuned it up. Proper tune & alignment is the way to go, if it had not already been done.
__________________
Secret Squirrel
K40 CB circa 1984 with ST65DX mic in the mobile
  #6
Old 07-16-2009, 04:17 PM
Senior Member
Default
And Bob's is one of the few you can trust. Sounds like you have a decent local guy to work with too there squirrel. Those Uniden 510xl's are rocking little radio's for their size.
  #7
Old 07-16-2009, 08:38 PM
Senior Member
DJboutit is on a distinguished road
Default
Here is a 40w mod but you have to swap out some parts
http://www.cbtricks.com/miscellaneou...bra_25_mod.pdf
__________________
[URL="http://radiopirates.18.forumer.com"]
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
