Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
RFX-75 on Cobra 2000GTL
Reply
  #1
Old 10-08-2009, 10:20 PM
Junior Member
Stump31 is on a distinguished road
Default RFX-75 on Cobra 2000GTL
Has anyone Hooked up a RFX-75 on a Cobra 2000GTL? Since the 148GTL and the 2000GTL have the same board I wonder if this upgrade will work on the 2000GTL?
Worldwide Radio Forum
  #2
Old 10-08-2009, 10:28 PM
Crazy_D is on a distinguished road
Default
The cobra 2000gtl is not the same board as the 148gtl. Its more like a 146gtl. Everyone thinks the cobra 2000 is a 148gtl or grant xl in a larger box with freq counter and power supply and its really not, though it does very much resemble the 148gtl/grant xl.
  #3
Old 10-08-2009, 11:38 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
Crazy D , the Cobra 2000s are basically 148s . 31 , it could be done on the 2000s "but" I truly doubt the power supply alone in the radio could handle the RFX 75. You could use the DC side of the 2000 with a good 20 amp power supply and that would work for you.
The 2000 is a good radio 31 , and they have not been built since 1993. You may be best to run a
seperate amplifer on the side if you can.
  #4
Old 10-09-2009, 01:56 AM
Robb's Avatar
WWRF Moderator
Robb is on a distinguished road
Default
I'd agree with SwitchKit. Hacking up a Cobra 2000GTL makes them less valuable in the long run. I'd run a used 100 watt external amp (about $50~) with it on a separate power supply (about $60~). You would get more power out, and the price wouldn't be that much more overall.
You would also keep that radio unmolested and more valuable too - which is very big deal at this time. The Cobra 2000GTL power supplies aren't the greatest or the strongest as SK said, and you would destroy it before long if you ran the RFX...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...World Radio One-One Northern CAL - Standing By..."
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Brand New Reproduction Cobra 2000GTL Due Out This Fall !!! Cotton Mouth CB Band and CB Radios 13 01-01-2010 05:53 AM
LesComm 8719-192 Expa kit, Cobra 148GTL & 2000GTL TonyV225 General CB Services Discussion 9 10-04-2009 07:46 AM
rfx 75 in cobra 29 ltd johnecashflo Tech, & Repair 32 07-12-2009 11:42 AM
Stock Cobra 2000GTL "air noise" on TX Crazy_D Tech, & Repair 13 09-30-2007 01:33 PM
Cobra 2000gtl built in power supply....... Phil501 Tech, & Repair 1 09-07-2001 04:06 PM
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
