Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
power supply
Reply
  #1
Old 11-02-2009, 05:08 AM
Junior Member
Chatter is on a distinguished road
Default power supply
what power supply should i be using for a palomar 225? how much current do you think this thing draws? power is clipping, no dxing.
please help!!!!
Worldwide Radio Forum
  #2
Old 11-02-2009, 06:30 AM
Wire Weasel's Avatar
Honkus Maximus
Wire Weasel is an unknown quantity at this point
Default
Can't go wrong with an Astron 35 amp like the hams choose. Over the net at any ham supply like Ham Radio Outlet or Amateur Electronic Supply or Gigaparts ect...
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
  #3
Old 11-02-2009, 07:38 AM
Senior Member
Carl is on a distinguished road
Default
18 19 amps tops, they have a 20amp link inside them if its a modern 225. ive found that running on medium with a low drive will be the best for those amps. generally high only distorts it. keep in mind you need to double the ouput power to see a 1/2 s unit gain on the other end. low is more than you will need in most cases. if you need more power a better antenna is a better idea.
more than likey it will draw around 15-16amp on high. pick a power suppply that will handle that constant. most power supply only handle peak at what there listed and it may be only a milisecond they can do it. nothing smaller than a quality 26 amp supply. the cheaper the supply the larger it needs to be.
the astron 35 would be rock solid for you. good power supplys that seem to be more relailbe than the pyramids in my experence. it will give you a little room to grow in the future.
__________________
KC0WRG / cdx001
  #4
Old 11-02-2009, 09:40 AM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
http://www.eham.net/reviews/detail/5204
__________________
  #5
Old 11-02-2009, 10:37 AM
SF509 is on a distinguished road
Default
i use a MFJ 35 amp .............
  #6
Old 11-02-2009, 05:58 PM
Junior Member
Default
cool, thanks for the feedback everyone
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Just wanting to share with you all my new power supply Cotton Mouth Installation & Station Setup 10 08-22-2009 09:04 PM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 09:16 PM
CHEAP Power Supply Hook948 Tech, & Repair 14 04-25-2007 08:25 PM
Iota Power supply Lazybones1222 Announcements & Open Forum 6 06-13-2006 08:34 AM
Powered by vBulletin®
