If any radio had a chance to sit around for awhile - chances are that the pots may need to be cleaned. That may explain why the squech isn't working - the pot may be dirty. Hear any scratching sounds in the speaker when any of the knobs are turned? That is a dirty pot if it does...
Another thing - just turn it on and let it set for a few hours w/o messing with it. Electrolytic caps are funny that way. Also: do you have a 50 ohm dummy load and a power meter? Don't try to key up the radio w/o one. Or - use a known good antenna.
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
