Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 2000GTL Help
Reply
  #1
Old 02-04-2010, 06:24 PM
longhaireddwb's Avatar
Senior Member
longhaireddwb is on a distinguished road
Default Cobra 2000GTL Help
I got this 2000 and after a bunch of funds out of my pocket it now works. The problem I'm having now is that the modulation meter pegs hard when I'm talking. I can't seem to find an adjustment to this meter.
Can anyone point me in the right direction to turning down the sensitivity of this meter? If there's no adjustment then I'd be willing to put in a resister in the right place if I could find someone to tell me where the right place would be.
BTW, The limiter has been cut! Could this be part of my problem? Well, R131 has been cut which I understand opens up the AM side but not the SSB side. I keep the mic gain down to just under distortion but the meter still pegs hard. I'm afraid it going to break!
This meter is also the SWR meter when you flip the switch but I don't want to throw the SWR way off.
Help...
__________________
Yaesu FT950, Yaesu 2900, Galaxy 48T, Galaxy 94HP, 98VHP, Plus a dozen or so little radios!
  #2
Old 02-04-2010, 06:52 PM
Quiksilver's Avatar
Senior Member
Quiksilver is on a distinguished road
Default
I would find a very reputable tech that specializes in the 2000's and have him/her check it out. Cutting the limiter is a no-no on these rigs. I would not take it back to the person you donated your hard earned money to.
Rogerbird is an expert on the HR2510 line,and he's from your area. Maybe he knows a Cobra tech in that area.
JMO
  #3
Old 02-04-2010, 06:55 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
Help...
I think you answered your own question.
  #4
Old 02-04-2010, 06:59 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Modulation meter adjustment is VR7 from what I can find on the web...
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #5
Old 02-04-2010, 07:07 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
i think Robb is on the right track.
in some MB8719 radios, like the cobra 148GTL and the uniden Grant XL, the AMC adjustment is VR7.
HOWEVER!!!
go to the base station models of either of these radios and you will find that VR7 controls the modulation meter adjustment.
in the cobra 2000GTL, the AMC adjustment is VR12, or cut R131 and use the mic gain on the front of the radio as the AMC.
on the president/uniden madison, there is no AMC adjustment. just a fixed resistor (R130 in holes marked for a diode) with a value that keeps the modulation under 100%.
most likely, someone used the tune up info from the 148GTL to tune up your 2000GTL and turned VR7 all the way up looking for more modulation.
Set VR7 so that when you say "ahhh" into the mic, with the mic gain all the way up; the meter moves almost all the way to the right.
then when you set the mic gain where you like it, (best is between 12 and 3 o'clock IMO) you will not be pegging the needle.
good luck,
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #6
Old 02-04-2010, 07:47 PM
Senior Member
Default
Thank you all for the quick response. I will give VR7 a try. And then VR12 if I can't find VR7. And as you said Loosecanon I like the mic gain around the 2 o'clock position myself. Lots of modulation and just under the distortion. Ill let you all know how it turns out. I'll dive in right now!
__________________
  #7
Old 02-04-2010, 07:54 PM
break on through
Default
if R131 is cut, turning VR12 will not have any effect, as it is effectively removed from the circuit.
as for where to set VR7, if you have an external modulation meter, you can set the mic gain on the radio so the external meter reads 100% and then set VR7 so the internal meter reads the same.
VR7 is located just in front of the main filter capacitor C172.
just to the right of L6.
__________________
  #8
Old 02-04-2010, 08:03 PM
Senior Member
Default
OK, I don't have any clue what VR12 does! It don't control modulation, SWR, Watt meter, Modulation meter, Freq. I just put it back where it was!
I adjusted VR7 and now my meter needle quit bouncing off the far side! Much better! And the SWR readings are not messed up. Just what I was wanting. Thank you all for the help.
This has to be the fastest question, answer and fix ever on the forum!
1hr 39min.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RFX-75 on Cobra 2000GTL Stump31 CB Band and CB Radios 13 11-09-2012 03:49 AM
cobra 2000gtl channel kit/mod???which is better?? slim cdx285 General CB Services Discussion 10 10-26-2011 03:43 AM
Brand New Reproduction Cobra 2000GTL Due Out This Fall !!! Cotton Mouth CB Band and CB Radios 13 01-01-2010 05:53 AM
Cobra 2000gtl cbkidd1 CB Radio Gear SwapShop 2 12-07-2009 11:13 AM
LesComm 8719-192 Expa kit, Cobra 148GTL & 2000GTL TonyV225 General CB Services Discussion 9 10-04-2009 07:46 AM
Powered by vBulletin®
