Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
no tx on cobra 29 ltd
Reply
  #1
Old 10-17-2010, 06:53 PM
Junior Member
scootter is on a distinguished road
Default no tx on cobra 29 ltd
got a cobra 29 ltd no tx and no pa. changed final and driver but no change, you can hear mic key up on speaker but no power on meter and light go's out. it also has low power at t1 so i put in a new one but still low power like 4 to 5 watts, my other radio has 13 watts.
  #2
Old 10-17-2010, 07:16 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
5 watts peak output?
There's a chance the the driver is what is showing that 5 watts; and the final isn't working. Seen that a couple of times. Could be something else; but I would check that first. If you have another final laying around - replace it.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 10-18-2010, 04:52 AM
CTStallion's Avatar
Senior Member
CTStallion is on a distinguished road
Default
No TX AND no PA, could be either microphone, mic jack, CB/PA switch or wiring, wiring from mic jack, and/or audio IC chip. I'd check those FIRST, and then move on from there.
Once I got the PA function working, then I'd move on to the RF portion.
Keep us posted.
Good luck!
__________________
Icom, Heathkit, Ameritron & MFJ HF Gear
Kenwood, Yaesu, & Alinco VHF/UHF Gear
Ranger, Galaxy, Uniden & Cobra 10 - 12 Meter Gear
Ten-Tec 'T-Kits' (love the lil buggers!)
Lotsa Homebrew & Tube Gear
Homebrew Antennas (HalfSquares, Bazookas, Wire Arrays) HF & 6M
Shakespeare ABS-1600 Army Stick 10 - 12M
Hustler & MFJ VHF/UHF Antennas
  #4
Old 10-18-2010, 08:28 AM
Senior Member
The Jerk is an unknown quantity at this point
Default
Quote:
Originally Posted by scootter View Post
...and light go's out.
Does this sounds like a power supply issue?
  #5
Old 10-19-2010, 07:12 PM
Junior Member
Default no tx cobra 29ltd
thanks guys for the help still checking it out,also trying to get my bench together. just got a tower for my antenna also trying to finsh the drywall in my new radio room. to many things to do and not enough time.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
COBRA 148 GTL Review Robb CB Band and CB Radios 47 11-12-2013 05:04 AM
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
Expo Expander 100 S+ and S- kits TonyV225 CB Radio Gear SwapShop 1 08-18-2010 10:09 PM
Brand New Reproduction Cobra 2000GTL Due Out This Fall !!! Cotton Mouth CB Band and CB Radios 13 01-01-2010 05:53 AM
EXPO 100 EXPANDER KITS S+ AND S- KLV 550 BASE AMPLIFIER TonyV225 CB Radio Gear SwapShop 0 12-08-2009 12:51 PM
Powered by vBulletin®
