Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 142 gtl Transmit problem.
Reply
  #1
Old 11-09-2010, 04:25 PM
gogo_gadgit is on a distinguished road
Default Cobra 142 gtl Transmit problem.
I used the radio before I went to work, came home, and now it dosn't transmit at all. The Meters don't move, the light dosn't turn red, alsmost like it was a microphone problem, but its not, I tried about 5 mics, and nothing,
there isn't a relay in the rig, so what else can I check or replace,
  #2
Old 11-09-2010, 07:22 PM
Senior Member
North Texas Mudduck is on a distinguished road
Default
is it in PA mode?
__________________
Anyone who wants to come to America legally to make a better life for themselves and their family, who are willing to respect our laws, customs, traditions, our people, our flag and are willing to assimilate, then welcome to your new home. For those who continue to fly the flag from the hellhole you came from and refuse to respect this country and all it stands for and expect us to change our laws, customs, language etc to accomodate you, feel free to leave anytime
  #3
Old 11-09-2010, 08:22 PM
Default
no, but i did flick the switch and put it on pa mode,, and when you key up the mic the green light goes out (rx light)
  #4
Old 11-09-2010, 08:24 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Did anyone else have a chance to mess with it while you were out?
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #5
Old 11-09-2010, 10:29 PM
Senior Member
Shockwave will become famous soon enough
Default
First you need to rule out if it's a PLL issue. Do this by checking to see if the radio is actually able to receive signals on the channel you are tuned to. If it does this, the PLL is likely to be locked. Then we have to suspect it may be a voltage switching issue. If you ruled out mic connections and checked the internal connector also, then look at the 8 pin MB3756 voltage regulator mounted next to the audio chip on the heatsink to the right. It's been a while but at least one pin should go from 0 to 8 volts on TX. I think it's pin 8. If that's not happening, you may have a shorted capacitor or this chip could be bad.
To determine if the chip is working check pin 5 to see if the control voltage changes from RX to TX. If not you probably have a shorted cap on the control line. If the control line pin 5 changes and pin 8 doesn't have 8 volts on it in TX, lift the pin from the board and check the pin again. If you still have no 8 volts on the pin in TX the chip is probably dead. If there is 8 volts, you may have a short on the load side of the chip. Good chance it's a cap. They are getting old.
  #6
Old 11-10-2010, 03:36 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Ok,
I take it the receiver is working? Just want transmit....
Lets take the easy route first. Check pin 8 of IC 5. This is your 8 volt regulator. You should have 8 volts there.
If the receiver is working then the TX supply should be ok, but we need to see if TR37 is pulling pin 2 of IC 5 low to switch it in TX mode.
The emitter of TR37 is the tx line to the mic plug.
  #7
Old 11-10-2010, 10:11 AM
Senior Member
Default
I'm only looking at the data sheet for the MB3756 and it indicates pin 2 it the main supply voltage to the chip and not the control line. Pin 2 should have constant 12 volts on it and pin 5 should be the transmit and receive control line to the IC.
  #8
Old 11-10-2010, 12:02 PM
Radio Tech's Avatar
Radio Operator
Default
Quote:
Correct,
I guess I did not word that good enough. If the circuit of IC 5 is bad, then when TR37 is switched to transmit, pin 2 will go low if there is a shorted circuit. If pin 2 (supply) goes low, probably a bad cap in the T/R switching circuit or an internal short in the IC itself.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
COBRA 148 GTL Review Robb CB Band and CB Radios 40 11-24-2011 07:39 PM
Cobra 150 GTL DX Problem Mod Wire Weasel General CB Services Discussion 1 08-01-2010 02:39 PM
Cobra 2000 gtl transmmit problem badcordoba CB Band and CB Radios 7 02-26-2009 03:28 PM
Powered by vBulletin®
