Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
cobra 89XLR
Reply
  #1
Old 11-19-2010, 06:50 PM
Junior Member
HeloThunder is on a distinguished road
Default cobra 89XLR
I have a chance to buy one of these radios, and i wanted to ask you guys if you think the price is right, here is what has been done to it.
Recapped: All electrolytic capacitors are replaced with high grade Nichicon's Audio line.
Beefed up power supply: 10 amp power transistor, heavier heat sink, 3 amp diodes in the bridge, 3x filter capacitor.
Higher power final: 2SC1307, new OEM part installed
Wider bandwidth 455 KHz IF filter: Installed +/- 6 KHz wide filter for improved RX fidelity.
Variable TX power: Rear panel control, 1 to 6 watts dead key, 22+ peak.
Switchable Mic AMC (automatic modulation control): Front panel switch. AMC on position is set not to exceed 100% modulation. Off position disables AMC.
Accessory TX relay Key: Switchable relay installed, normally open contact will switch an accessory on PTT. The CB/PA switch is wired to enable this feature. The PA output jack on the rear panel is wired for Relay PTT out
Uppers/Lowers/+/-10 KHz: Front panel switches, comes with printed chart. New frequency range is 26.875 to 27.665. Please follow your regions rules and regulations when operating radio equipment
noise blanker/Lights/Display kill switch installed.
(A small, low current red LED mounted in the center panel will come on when lights are off indicating power saver mode. This greatly reduces current drain if operating from an emergency battery. A DC power cable is provided for battery hook up.)
That is what has been done to the radio, is this rig worth over $100? From the pics, it is a really nice rig and a lot of time was spent updating it.
  #2
Old 11-19-2010, 07:11 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
id say it depends on who did the work . its had a lot of work done to it and IMO would really be a premium 89 , if the person that did it did quality work . i imagine if someone paid someone to do the work that they paid well over $100 . no SSB . but it could be a very very fine AM radio
  #3
Old 11-19-2010, 07:48 PM
unit_399's Avatar
EL CAPO
unit_399 is on a distinguished road
Default
The cobra 89xlr(base) and the Cobra 29xlr (mobile) use the identical chassis. The XLR-series Cobra radios were the BEST- PERFORMING AM radios ever sold by Cobra. The speech clippimg circuits in these radios worked so well, that the FCC banned these circuits in rsdios after 1978-
  #4
Old 11-21-2010, 05:52 PM
jopcobra89 is on a distinguished road
Default
Good radio with quite a few upgrades, but value is fairly low since it's AM only.
If you want it really bad $100 wouldn't be insane, but I'd feel better paying $60 to $75. Still over my limit for any AM only base, but it's basically the best AM base ever produced and with all of the extras should serve you well for years.
  #5
Old 11-21-2010, 05:57 PM
T23 T23 is offline
Senior Member
T23 is on a distinguished road
Default
This is a nice base I have one in VERY good cond. I traded a digital camera for mine ( a $5.00 2 megapixel ) I use a turner Super Side Kick Mic with mine... Nice radio. If you want a radio that looks the same with SSB go for a 2000GTL. I wouldent pay over $60 myself for the paticular unit you mentioned, I saw that AD myself...and its cond. wasn't too well.
T23
  #6
Old 11-24-2010, 05:26 PM
Junior Member
Default
Well, i took a chance and the radio is on its way, probably around friday or so. I am still trying to figure out what antenna to get.
I wll probably wind up getting a dipole, since i wont have any help putting up an antenna, so it will be easier to lug some wire up a tree as opposed to 3 six foot sections of fiberglass, or aluminum.
If i had some help to put it up, it would be easier for me to choose. I have come across an antenna called a balcony buster, on fleabay, it would be perfect for me, but i can't find much info about them anywhere online.
  #7
Old 02-23-2011, 01:24 PM
missourimule is on a distinguished road
Default Cobra 89XLR
I had one of those several years ago.it was a good one.I saw one some time back with a D104 at a garage sale .I was tempted but what stopped me was it didnt have sideband.They was only asking $20.00 for it and the mic.Right now I have 2 of the 135's, one 23 channel and the XLR 40 channel.And my alltime favorite, the 139XLR.People think Im crazy for likeing it better than a 2000.I prefer the looks of the 139XLR and 142 over the 2000.I had a 142 about 10 yrs ago.It bled over a jukebox a block and a half away , plus blew up the preamp in the neighbors stereo.And that was straight readio with a Turner +2 desk mic and A99 antenna.But you got a decent buy tho,it has that 858 chipJust hope there wasnt any Golden Screwdrivers in it.The man that does my work retired from Motorola.
  #8
Old 02-23-2011, 04:50 PM
wavrider is on a distinguished road
Default
I had one in the early 80's. It is an audio screamer, good receive also.
The dipole may not be the best choice of antenna depending on what you are looking to do.
It will work fine for DX but local rag chewing you may need a vertical.
Lots of threads on this forum and Marconi has some really great documented tests between different types of verticals.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
COBRA 148 GTL Review Robb CB Band and CB Radios 47 11-12-2013 05:04 AM
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
Cobra 89XLR 1969 and 2166 MOD Instructions. ses CB Radio Modifications 0 06-05-2010 10:57 AM
Cobra 89xlr Converted? KB1TPX CB Radio Modifications 5 07-14-2009 06:39 PM
cobra 89xlr no carrier troyota General CB Services Discussion 6 11-16-2008 06:08 PM
Powered by vBulletin®
