02-13-2013, 06:43 AM
| Junior Member | | Join Date: Oct 2011
Quote:
Originally Posted by Toll_Free If you REALLY want to increase the complete talk-power on those units (I've been working with the 858 Unidens and the processors / clippers in them for about 25 years), add a diode or two to the POSITIVE side. This will still allow for some amount of clipping (good), but will INCREASE the positive side.
OR, keep a SILICON rectifier diode on the positive side, and a germanium or shottkey on the negative side. I did just this in a Lou Franklin clipper, and it make it about twice as loud: Not bad when you consider the processor gets the same compliments by itself!
--Toll_Free | I have a TRC-457. I'm interested in the two mods above to the diode pair/clipper that comes stock. What net effect would adding a diode or two in series with d21 (positive side on my radio) or replacing the stock diode @ d22 (negative side) with a schottky have? I assume you'd create favorable conditions for higher positive peaks while still keeping the negative peaks in check? (Asymmetric modulation instead of ~100%)
Anyone try this on an 858 radio's clipper? I have a schottky diode sitting right here... |
