Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Gear SwapShop
Amateur Callsign Lookup
Enter Callsign:
MACO 200 10 METER LINEAR
Reply
  #1
Old 08-31-2010, 11:06 AM
Junior Member
xjamforthelambx is on a distinguished road
Default MACO 200 10 METER LINEAR
So, ebay yanked my listing of the MACO 200 10 METER LINEAR amp. Basically saying this item can't be sold on eBay. I've seen others sell, so I'm not sure why this one was flagged. Anyhow, I attached some info the FCC gave me. Does anyone know why they would have yanked my listing? I'm not a CB/Ham radio guru, I just like to buy/sell old electronics.
I wanted to give you the opportunity to make me an offer for this amp. Historically, they have been selling between $125 and $175 plus shipping. If you are interested in making an offer, please contact me.
Details: Unit powers on but I don't have the equipment to test it. There are 4 6LB6 tubes (12 pin). 3 are GE, 1 is Realistic. Let me know if you need more info.
  #2
Old 08-31-2010, 12:28 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
And this has nt been tested??
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 08-31-2010, 12:35 PM
Junior Member
Default
I powered it on only. Saw the tubes light up. I purchased it from an estate auction of an avid CB/Ham radio collector.
  #4
Old 08-31-2010, 12:51 PM
Carl's Avatar
Technologicaly Challenged
Carl is on a distinguished road
Default
any amplifier that has more than 6db gain on 10m is illegal, if it were home made you could build one per year if you were a ham and be legal. this is why the old 60's tube amps had a blank spot on the selector so it could be enabled by the end user. even new amps are like this, anything new has 10m disabled from the factory. most are easy to convert however, like ameritrons generally have a single green wire grounding the selector that needs to be removed.
the stuff you posted is just for export radio's, not amps. like i said those have been illegal sence the 60's if they will amplifiy a 10m (or 11m signal). ebay will continue to pull it.
__________________
NĜAAT
  #5
Old 08-31-2010, 01:00 PM
Junior Member
Default
Just so I'm clear, this is a 10 meter amp and is illegal to run in its original state...correct?
So, can I actually sell this? Is there a legal use for this equipment?
thanks!!!!
  #6
Old 08-31-2010, 01:01 PM
Carl's Avatar
Default
Section
302(b) of the Act2, and Section 2.815(c) of the Commission's
Rules7 requires FCC Type Acceptance (or Certification) of
External Radio Frequency Power Amplifiers (or amplifier
kits) capable of operation on any frequency or frequencies
below 144 MHz. Furthermore, Section 2.815(b) of the
Commission's Rules prohibits External Radio Frequency Power
Amplifiers (or amplifier kits) capable of operation on any
frequency or frequencies between 24 and 35 MHz.
__________________
NĜAAT
  #7
Old 08-31-2010, 01:05 PM
Carl's Avatar
Default
sure you can sell it just don't get caught by uncle charlie. you will be fine if you sell it outside of ebay, they will continue to pull it until they get pissed off enough to ban your account. selling on a private forum like this and many others is generally considered safe, to the best of my knowledge the fcc field agents have more important places to be than hunting down sites on the net. the only one i have heard of getting in trouble was qrz. they got a nasty letter from the fcc telling them to stop allowing exports and amps capable of illegal operation or they will get slapped for a 10k fine for each offense.
__________________
NĜAAT
  #8
Old 08-31-2010, 01:13 PM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
Quote:
Originally Posted by Carl View Post
any amplifier that has more than 6db gain on 10m is illegal...
i do believe the correct spec is :15 Db gain max on ANY band 97.317 (a) (2)
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maco 200 capacitor replace intercepter Amplifiers 7 12-23-2009 12:45 PM
RMS HT 200 Linear amp delta Amplifiers 1 10-05-2009 01:39 PM
RMS HT 200 Linear amp delta Meters, Mics & Other Accessories 0 10-03-2009 04:45 AM
Powered by vBulletin®
