Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Gear SwapShop
Amateur Callsign Lookup
Enter Callsign:
Glen Martin Voyager track antenna lift goes 90ft up the side of 45G tower
Reply
  #1
Old 12-09-2010, 06:21 AM
videorov is on a distinguished road
Default Glen Martin Voyager track antenna lift goes 90ft up the side of 45G tower
This Glen Martin antenna track system is difftent then the hazer. It has two tracks that fasten onto the outside of the 45G tower face. This allows you to have guy wires hooked up on 90ft of tower. When you crank the antenna up the tower you can drop a set of the guys and then when you are pass them hook them back up and keep going up the tower. I have the manual and all hardware which is all stainless for attaching the aluminum track.Nice system if you want to go higher then 50ft the regular Hazer goes. Have manual for too.More pictures over on hamradioclassifieds.com $3000 941-567-0115
  #2
Old 12-10-2010, 09:12 PM
Senior Member
distortion is on a distinguished road
Default
How does this work exactly?
__________________
1992 Suburban - Rolling Base Station
16 Pill - Monkeymade - Galaxy 33HML - Leece Neville
  #3
Old 12-10-2010, 09:26 PM
Default Voyager Hazer antenna lift
Well there are tracks that bolt onto the side of the tower. The sled has
wheels that lock into the special track so it can't come off.
There winch connects to a continuous cable looped to the top through
a pulley and back down to the winch. The sled is just clamped to a section
of the cable and it goes up and down the track as the cable goes around.
That way you don't have to worry about winding up a bunch of cable when
you crank it up. You are just moving the cable around the loop. Its a nice
design they came up with but not cheap to build.
  #4
Old 12-11-2010, 09:22 PM
Senior Member
Default
How does it unhook re-hook guys so you can run 100+ ft towers and such with multiple sets of guys?
__________________
  #5
Old 12-12-2010, 12:13 AM
Default
You unhook guys maybe only two are in the way for the yagi to get past. You unhook
them from the ground anchor and bring them into the tower then crankup the antenna
up past that point and then hook them back up and keep going.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super C antenna...this is really neat Moleculo Amateur Radio Antennas 14 01-19-2014 02:04 PM
My Interceptor 10k review (w.pics) gc505 CB Antennas 41 09-29-2008 07:37 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
