Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Cobra 148 gtl Philipi
Reply
  #1
Old 01-22-2012, 07:35 PM
Junior Member
flash1van is on a distinguished road
Default Cobra 148 gtl Philipi
I am trying to mod my 148 for 10 meter operation. I got the crystal but can only get it to key up at 28.245 but no higher. I was hoping to use a switch and keep 11 as well but don't realy care. Any ideas?
  #2
Old 01-22-2012, 07:50 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Sounds like you picked the wrong crystal for 10m - to me.
Using a DPST switch, stock/and 10m crystals, small piece of breadboard, and two variable caps, it might be possible to run both. Two parallel circuits and a switch between them - basically. Never done it myself; but in theory it might work. All you would need to do is wire both crystals/variable caps on a board and then wire them to the main board where you took the stock crystal from. Only one problem that I see, is that the VCO voltage might not be right for both bands and might unlock the PLL on one band or the other. Even that can have a workaround.
The OTHER consideration is to open the clarifier and use a 'super diode' (diode/choke) so that it will slide ~6kc's.
Re-aligning the VCO, 1st osc, and 2nd osc will be necessary too.
Will it work?
Maybe; maybe not . . .
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #3
Old 01-23-2012, 04:32 AM
RatsoW8's Avatar
RatsoW8 is on a distinguished road
Default
Quote:
What frequency crystal did you install?
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #4
Old 02-08-2012, 08:11 AM
Junior Member
Default
Used an 11.730 crystal, got it to work up to 28.240 even after adjusting the vco. As for the slider, got 16 kc down and 6 up...
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
COBRA 148 GTL Review Robb CB Band and CB Radios 40 11-24-2011 07:39 PM
Schematic/Service Manual for Chinese Cobra 148 GTL? unit248 General CB Services Discussion 3 09-12-2011 11:40 AM
cobra 148 gtl chan display mod SHOCKER CB Radio Modifications 6 09-05-2010 07:21 PM
Nice Cobra 148 GTL Malaysia with Extras Wire Weasel CB Radio Gear SwapShop 0 08-01-2010 12:26 PM
Powered by vBulletin®
