03-09-2012, 05:08 PM
 | Yup | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
Quote: |
INPUT POWER: 1-6W AM/FM - 1-12W SSB/CW,
| The variable power mod is the ticket for the linear running properly. If that amp will run at 1 watt; then set the radio output for that. Don't be hung up on the output numbers. No one will notice 40 watts less; they will notice a crappy sounding transmit - though.
As far as the swing mod goes; that will depend on how much modulation%/mic gain you use. Again, a crappy loud radio sound isn't always clear - and therefore - not better. Best get a radio check from a local operator that can give you a valid report. Clean sound is always better understood either locally or even distantly . . .
__________________ BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000. MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770. "...2 WR-011..."
