Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Can I replace a 2SC1969 with a 2SC2312?
Reply
  #1
Old 03-14-2012, 07:05 PM
Junior Member
Tetra is on a distinguished road
Default Can I replace a 2SC1969 with a 2SC2312?
I have a very old side mic 148 that appears to be in need of a final. I dont have a replacement 1969, but I have a few old 2312's. Can I just do a straight swap? If so, should the final bias be set to 50 mA like the stock 1969?
Thanks.
  #2
Old 03-14-2012, 07:20 PM
unit_399's Avatar
EL CAPO
unit_399 is on a distinguished road
Default
Yes it will work as a straight up swap. And ... yes set the bias to 50ma like the stocker.
- 399
  #3
Old 03-14-2012, 08:28 PM
mr_fx's Avatar
Senior Member
mr_fx is on a distinguished road
Default
yes and the 1307 will swap too
__________________
QTH: Vert 160/80, Fan 40/20/10, Fan 17/15/12/6, 2m J pole, 2m halos Mobile: 12/15/17/20/40, 10, 6, 2/440
  #4
Old 03-15-2012, 06:33 AM
n0zna's Avatar
Senior Member
n0zna is on a distinguished road
Default
a 1307 or a 477 will do also...73 de JW
__________________
FT450d,TS520,RCI2950dx and 2980wx,seven Siltronix 1011d,FT250r ht,motorola maxtrac300 uhf SWAN1200x
  #5
Old 03-15-2012, 06:41 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
A word Caution
You can replace a 1969/2312/1307 with a MRF 477, BUT the Base/Emitter/Collector pin out is not the same.
Pins # 2 & 3 must be crossed, and insulated with a small pc of heat shrink to prevent them from shorting.
1306/1307 driver/finals are rare as hen`s teeth to find nowadays, they have not been made for a very long time.
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #6
Old 03-15-2012, 09:46 AM
n0zna's Avatar
Senior Member
Default thats right,
the do need crossed...been so long since i fooled with trans...i like glass,tubes...73 de jw
__________________
  #7
Old 03-15-2012, 12:59 PM
Junior Member
Default
Thank you all!
  #8
Old 03-15-2012, 06:22 PM
unit_399's Avatar
EL CAPO
Default
DE NADA.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2sc1969 vs 2sc2312 jbenally33 CB Band and CB Radios 14 07-05-2012 02:40 PM
Looking for 2SC2312 finals Turbogus CB Band and CB Radios 10 06-12-2011 02:01 PM
2sc1969 replacments gogo_gadgit General Ham Radio Discussion 2 10-27-2010 08:35 PM
maco 200 capacitor replace intercepter Amplifiers 7 12-23-2009 12:45 PM
I now have a new forum to replace my old one... The Defpom General CB Services Discussion 5 11-10-2004 05:05 AM
Powered by vBulletin®
