Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
142GTL Final
Like Tree1Likes
Reply
  #17
Old 12-26-2012, 06:17 AM
Junior Member
azscr4mbl3r is on a distinguished road
Default
Hey Thanks , I had read those posts of yours here and on other forums. Still that MV12YH seems pretty mysterious doesn't it? I have my bench DVM and scope setup now and my generator I just got on the 24th.. So I did poke around on it yesterday briefly. I am leaning toward there being no carrier. I am going to try to look at waveforms I have on the 148 and try to find a similar point on the 142 to compare with because I see modulation back at the predriver are but it doesn't seem to be riding on anything... Thanks again for taking time to help!! These mods done and not done and the age of the unit makes this a fun challenge.
-Allen
  #18
Old 12-26-2012, 11:58 AM
Junior Member
Default
WooHoo I got another one ( Ebay Treasure ) 44 bucks works good and unmolested. I have a "go by" now LOL. other than a hum is rx and tx fine 3-4 wats out in AM. Listening to LA right now.
-Allen
  #19
Old 12-28-2012, 06:29 AM
Junior Member
Default
Back on the old 142gtl I removed the crystal switch mod. I put the L37 and 38 back to their proper places. I touched up a few shady solder joints. I checked the regulator it seemed odd to me as it checked 489 and 508 on the diode setting... two legs lifted I have seen them a few off like 509 507.. I'll keep it in mind..40Ma and 45Ma on the biasing TP's but ZERO watts DK and OK modulation... Still trying to find any and all mods that have been done to her and put them back to stock.
-Allen
  #20
Old 12-28-2012, 10:00 AM
Junior Member
Default
At the base of TR38 I get a nice waveform but it seems to be folded over and is all negative going and about .2 volts I pulled it and checked it and it tested good. IC6 SO42P is the source I will check those in and out and see if it is bad.
-Allen
  #21
Old 12-28-2012, 10:11 AM
Senior Member
Grinder74 is on a distinguished road
Default
I just bought a midland 13-895(Cobra 139) and have the same problem. Some modulation but no power. I'm hoping this thread will help me also. I have no bench equipment so I can't help.
  #22
Old 12-28-2012, 12:23 PM
Junior Member
Default
Grinder you can do quite a lot with minimal equipment. I multimeter is under 20 bucks which you can use for car and home repairs as well as electronics. An inexpensive soldering pencil and some solder also very inexpensive. Your eyeballs... That is most often all you need. Of course some decent hand tools screwdrivers mostly. Probably the most common thing is a bad final. Probably just a 2.00-5.00 dollar part
good luck,
-Allen
  #23
Old 12-29-2012, 08:51 AM
Junior Member
Default
Well I have taken a break and I am working on a 148GTL which isn't as modified. I did pull a few possible bad parts to check or replace. TR 40 2sc496. was good. TR 38 2sc1973 was good. I replaced a few caps that might have caused issues with higher voltage ones. I had one oddball that was a 1000 uF but the schematic and parts list said was 470uF C118 over by the audio chip. MV13YH D47 I ordered because it seems to be questionable in both of these radios. We'll see! I rewired my Barjan noise cancelling mic which never worked right and now it does. It never occured to me that the mic turns the speaker on and off LOL I read that they don't receive if the mic isn't plugged in now I know why it turns the speaker on and off.
-Allen
Happy New Year.
  #24
Old 12-31-2012, 04:00 PM
Junior Member
Default
I checked the collector voltage on the driver and final and I have only +3VDC in AM transmit. 13.xx in SSB. Should be 5.4 VDC I think. Any ideas ?
TIA
-Allen
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 29 NH ST Final Replacement Wire Weasel CB Radio Modifications 2 05-26-2012 06:21 AM
high final bias current on 139xlr loosecannon CB Band and CB Radios 4 02-21-2007 06:23 PM
Question about final for Dwight D parkair General CB Services Discussion 5 09-19-2006 09:54 PM
HR2600 has a blown final..recommended repacements ? The Defpom General CB Services Discussion 13 11-03-2004 04:21 PM
2510 power seems to be dropping. Final or driver? Rogerbird1 General CB Services Discussion 5 02-19-2004 07:45 AM
Powered by vBulletin®
