Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Schottky Diode Mod For Galaxy DX 94 HP ?
Reply
  #1
Old 05-24-2009, 07:35 AM
Senior Moment
Wire Weasel is on a distinguished road
Default Schottky Diode Mod For Galaxy DX 94 HP ?
Anyone know of receiver mods for the 94HP Class to improve/reduce noisy receive?
Thanks!
__________________
Welcome to the WWRF. Plenty of Free Parking and with 5,000 posts you get egg roll
  #2
Old 05-24-2009, 04:45 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
should be D1, D2, D30, and D31 for the diodes.
the transistor to change will be Q17.
the parts list shows it as a 2SC1674 but i think Galaxy has since improved that part and is using a 2SC2986 or 2987; cant remember.
the transistor they are using now is just about as good as the 2999.
i didnt notice any difference when i replaced it in my 959.
the diode changes however, will help a lot.
dont forget to check Q54 to see if its a 2SB827 and not a 2SB754.
pretty sure Galaxy is using the 2SB827 exclusively now, but still worth checking.
if you do want to replace Q54, the 2SB817 is the part to use.
good luck, nice radio,
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #3
Old 05-25-2009, 05:57 PM
Senior Moment
Default
Thanks LC ! I'll check into all of this.
What's the part number for the Schottsky? TNX
__________________
  #4
Old 05-25-2009, 08:12 PM
break on through
Default
they are 1N6263 or, if you cant find those, you can use NTE583's.
either will work the same.
you can get the 1N6263 from mouser electronics.
here is a link:
1N6263
hope this helps,
__________________
  #5
Old 05-25-2009, 10:16 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
The transistor replacement is a 2SC2999; but there is a better version of it. The Sanyo 2SC2999 "E" is a bit more costly but is the 'cleanest of the clean' amping transistor. They can be had from B&D Enterprises:
B&D Enterprises: Part #2SC2999E-SPA
Two of the diodes are part of the detection circuit, and can make it a bit too sensitive - in the sense that they can even overload the receive. The other two diodes designated are used in the noise blanketer circuit. Cobra 29's only need 3; most other radios need 4. Truth is, the transistors are the parts responsible for knocking down the noise and improve the signal level.
Some radios often will have a better receive if two 2SC2999E's are used - one for the first IF stage amping and the other for the SSB receive amping. Their advantage in use is to give the receive more signal gain before noise. The diodes aren't always the most popular mod, but the transistors are always welcome to any radio - IMO. Personally. I would do the diodes too - I have done this to all of my radios when adding the transistors. After these mods, realignment of the radio isn't necessary - unless it needed it to begin with. These mods cannot right an out of tune radio; they just clean up its act favorably...
I've done a couple of Cobra 29's and 148's with really phenomenal results. Some think these mods are petty; I think these mods are useful and quite noticeable. I don't know what kind of IF transistors are in my Galaxy DX 99V. But if they are substandard and be cross exchanged, I will put the Sanyo 2SC2999E's in it - too. The receive in the Galaxy is already very nice, but it will still work better with the transistor mod.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #6
Old 05-26-2009, 05:38 AM
Senior Moment
Default
Thanks Rob !! Hey, still looking for the part # for the diodes.
TNX 73
__________________
  #7
Old 05-26-2009, 07:04 AM
Robb's Avatar
Yup
Default
THE Shottky diode number is a 1N6263, or a ECG583(?) I use the 1N6263. Thet are pretty cheap, and can be had for as little as $.03-.08 each. I would buy the best brand if available, since you don't need a lot and they are cheap. Buy the ST Micro or the ECG parts will do just fine if that is all you can get. The Sanyo Transistor is really the key...
__________________
  #8
Old 05-26-2009, 08:11 AM
Senior Moment
Default
Many thanks Rob, this will make a great reference thread for future use.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
