Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
anyone no witch vfo for tram titan 2
Reply
  #1
Old 07-25-2009, 01:52 PM
kj4mqa
kj4mqa is on a distinguished road
Question anyone no witch vfo for tram titan 2
does any one out there know witch vfo
will fit my tram titan 2 ?
i have a siltronix model 80 it is the 5 on back.
i tried it but nothing. i also tried the 3.
id like to have on on it.
any help would be great.
73s kj4mqa bill
  #2
Old 07-25-2009, 02:40 PM
555 555 is offline
Senior Member
555 is on a distinguished road
Default
sometimes they use the channel 23 crystal slot for the vfo
did you try it on channel 23?
__________________
Due To Price Increase On Ammo No Warning Shot will be fired. Sorry But Times Are Hard In Texas I apologize for any inconvience.
  #3
Old 07-25-2009, 02:45 PM
MisterFatty's Avatar
Poppin Fresh!
MisterFatty is on a distinguished road
Default
According to the Original Docs from Siltronix, none of the VFOs will work on the Titan II, Looks like it requires 13mhz xtals so #1 is closest with 11.5-12mhz output or so.... Next is the #5 with 10.7-11.x or so... Not sure if either of those will quite make 13mhz without mods though.
A Pal Model A is 11-12 and should tune 13 from what I recall. You can also hunt around for a Glenn Digital controller, or make something up. Crystals are a bit pricy now days, depending where you need to go may be an option. However you do it, the old Titan isn't very broad banded...
  #4
Old 07-25-2009, 05:07 PM
kj4mqa
Default ch-23
yes i did.
  #5
Old 07-25-2009, 05:15 PM
kj4mqa
Default ok thanks
ok thank you for the info.
it has a home brew on it but it drifts.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
