Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Radio Modifications
Amateur Callsign Lookup
Enter Callsign:
Cobra 148gtl, Unident Grant mods
Reply
  #1
Old 10-12-2009, 03:49 PM
Moleculo has disabled reputation
Default Cobra 148gtl, Unident Grant mods
Here is a good set of power/audio mods for the Cobra 148GTL. I couldn't find these in the search, so I reposted it.
Also applies to:
Cobra 148GTLF
Cobra 2000GTL
Undien Grant XL
Uniden Grant LT
1. Carrier Adjustment: VR10. If lower carrier is desired, change R196 near VR-10. Try about 270 ohms.
2. Change R114 to a 10K, and C46 to a .2 monolithic, this will widen up the audio on AM.
3. The AMC is TR-26. You can remove it, and still have good results on AM, the ALC for SSB is not effected by this. If you don't want the AMC disabled, leave it. the other way to disable the AMC is cut R131. Check both to restore AMC from previous mods.
4. If extra frequencies have been added, perform the following to widen up the band pass filters to recover lost power at the highest and lowest frequencies: C163 - 4pf, C41 - 3pf
5. R180 - Jumper it. This brings up the gain of the TX mixer.
6. IC TDA6130 - Pin 12 to ground through 100 ohm resistor. Upper left, pin 14 = ground.
7. Remove the AM regulator, (usually a 2SC1419) and replace it with a 2N6487.
8. C174 - remove, add 1000uf electrolytic. connect POS to base of yellow wire next to it. If the yellow wire is too far away, it might be easier to connect the POS leg to the leg of the AM regulator closes to the back of the chassis via the bottom of the radio.
9. For 148F, change C18 to a 1000uf electrolytic, 16V
  #2
Old 10-18-2009, 10:00 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
im surprised that those mods couldnt be found around here through searching, but then again, i have had many troubles with the way the search feature works on this forum.
i just have a couple of things i believe should be changed on the list.
these are just my findings, and should not be taken as gospel.
(unless you pray to the almighty loosecannon. then, go ahead LOL)
i will address #4 last.
5. the purpose in jumpering this resistor is to keep the bias from going negative.
(these are justin depolis's words, not mine)
6. this is the mod that increases the gain of the transmit mixer.
also, you might want to include the older chip that is used here: the S042P.
7. might want to mention the part number here. its TR41.
8. probably some different wire colors used in different chassis. maybe add that the negative lead of the cap goes in the negative hole left open by the removal of C174, and that the positive lead of the cap goes to the base of TR41. (lead closest to the rear of the radio)
9. dont know why this would only apply to the 148F.
this cap is in the mic circuit. the stock cap wasnt rated for enough voltage and would fail. increasing the value of this cap will help keep the mic from squealing when audio gain in the radio is increased.
now, for #4.
C163 can be increased to 4 or 5 pF, but increasing the value of C41 actually makes the tuning of L6 too narrow.
the effect will be that L6 will peak over a very narrow range causing the gain to fall off quicker towards the band edges than it did with the stock 2pF cap there.
a better mod is to leave C41 as a 2pF cap and solder a 1pF cap from the emitter of TR14 to the lead of C41 that connects to L5.
now, i must say here that these are my own findings, and i have never heard anyone else's opinion on this mod. i do know that this is what i observed personally.
just trying to help clarify things,
__________________
"Hatu hatu ziggedy beem bomm boom, hatu" -Mel Brooks
  #3
Old 08-12-2010, 09:10 PM
Klondike Mike's Avatar
Senior Member
Klondike Mike is on a distinguished road
Default
Quote:
Originally Posted by loosecannon View Post
>> ... C163 can be increased to 4 or 5 pF, but increasing the value of C41 actually makes the tuning of L6 too narrow. the effect will be that L6 will peak over a very narrow range causing the gain to fall off quicker towards the band edges than it did with the stock 2pF cap there. a better mod is to leave C41 as a 2pF cap and solder a 1pF cap from the emitter of TR14 to the lead of C41 that connects to L5.
LC, glad I came across your old post. I was going to follow along and change both c163 & c41 to 5pf. I'll do c163 for now and do the 1pf later when I get it. I'll let you know how it turns out.
PS: the document I'm referencing mentions removing c161. Your thoughts?
  #4
Old 08-12-2010, 09:20 PM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
The thief DePushdin really knew his stuff.
His technical expertise was only second to his dishonesty, what a shame.
Right click, save, lol.
__________________
  #5
Old 08-12-2010, 09:24 PM
74IN's Avatar
Senior Member
Default
I think it applies to the 148gtl, not the gtlf.
I had a GTLF (frequency counter model), and it was not up to snuff compared to the GTL (my Grant XL).
Sent it to DTB, got it back and was dissatisfied, until he explained that it was a completely different rig.
__________________
  #6
Old 11-25-2010, 09:09 PM
break on through
Default
CORRECTION!!!
just wanted to correct some info i was just reminded of.
in speaking about how to broadband L5, i stated to connect to the emitter of TR14.
it should be the COLLECTOR (middle leg) of TR14.
so the mod should read: connect a 1pF cap from the COLLECTOR of TR14 to the leg of C41 that connects to L5.
sorry about the bad info.
__________________
  #7
Old 02-24-2011, 09:25 PM
Senior Member
15minigrass is on a distinguished road
Default
So this will lower my DK below 1.5 watts right?
__________________
Mobile:
Prez Grant Export/Stock Mic
Black Widow 350V
Two 9" Predator 10K
RS SWR/Watt Meter
Base:
P/T COBRA 146GTL(Spare)
President Jackson
Turner +3 Hand Mic
Pyramid 25 Amp P.S.
Home Made Ground Plane Base ant.
  #8
Old 07-30-2012, 08:18 PM
Needle Bender's Avatar
Senior Member
Needle Bender is on a distinguished road
Smile
It should, I got mine down to 2/3w but it sounded like double sideband so I brought it up to 1.25w DK.
Reply
Bookmarks
Tags
148gtl, cobra 148gtl, cobra 148gtl mods, grant, mods, uniden grant lt, uniden grant xl
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Philippines Made Cobra 148 GTL Mods iceman78 CB Radio Modifications 12 07-30-2012 05:23 PM
Looking for cobra 1000 mods 941Texas CB Radio Modifications 10 01-13-2012 05:36 AM
cobra 148 gtl chan display mod SHOCKER CB Radio Modifications 6 09-05-2010 07:21 PM
Mods for the Cobra 200GTL DTB Radio CB Band and CB Radios 48 04-29-2008 12:20 AM
mb8719 pll 10k (able's) switch - uniden grant/ cobra 148 Carl General CB Services Discussion 3 06-25-2006 10:14 AM
Powered by vBulletin®
