Thanks Dirtfarmer,Ill havt to check that out and see if its real-time software or what.And keep at it you will get the code it takes a little practice and work,but things that have real worth are work my friend,you should be copying the w1aw cw practice on the air receiving is super good ,you need to OVERLEARN THE CODE ,then its like writing your name or reading ,Keep up the good work and let me know when you pass the code,also since you pass the code you should go for the General at the same time It wont hurt and you might have studied enough to pass that also.Take Care,73/GL/DX
DE-K8PG-Paul-CW LIVES
OFFICIAL O.O.
