WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Amateur Radio Related > Digital Modes Discussions
Notices
This is the place to discuss and learn about all the interesting digital modes: SSTV, PSK31, CW, Pactor, Amtor, RTTY, etc. This section is for those who enjoy or are interested in CW and Digital Modes.
Reply
  #1 (permalink)
Old 09-23-2006, 06:04 PM
Senior Member
cphilip is on a distinguished road
Default Best learner beginner cheapo set up?
Keyer and paddle set that would plug right in to my RCI 2980wx for learning which would hook up but also act as a practice unit? For say... well... let start with 100 bucks or less?
Used is fine if you know of some and ranges of ones you have seen sold recently if you don't.
Or perhaps a bit more but convince me to spend it now rather than later if thats going to be your tact on it. Or give me your rational for one or the other.
I just want to be on the lookout for one. And know the values and what kind I should be looking for. Best be knowledgable first so I am ready if a deal comes my way.
TIA
Phil
__________________
www.cphilip.com
  #2 (permalink)
Old 09-26-2006, 06:49 AM
Senior Member
N8YX is on a distinguished road
Default Re: Best learner beginner cheapo set up?
TIA
Phil
Straight key or keyer?
Or both?
If you can find one, look for a Ham-Key HK4. Has a set of iambic paddles and a straight key on one base. Next, look for a Trac 22/33 or MFJ electronic keyer. You should be able to pick both of these items up for less than a c-note.
Handy at building stuff?
Head over to MFJ's website and buy a Curtis 8044ABM or 8045A 'keyer on a chip'. Build up the circuit on a piece of perfboard then place in an enclosure of your liking. Cheap...last I checked, the chip was around $20.
  #3 (permalink)
Old 09-26-2006, 10:02 AM
Senior Member
Default
I found a used Bencher BY-1 and MJF Keyboard Keyer (which supposedly will run the Bencher too as it has been doing so) used for about 70 - 80 bucks. Would this be a good set up?
I am unsure of if it is a direct plug in for the RCI 2980wx as to the plug size that exits on the MJF... But probably can work around that by conversion if not...
__________________
www.cphilip.com
  #4 (permalink)
Old 09-26-2006, 10:54 AM
Senior Member
K8PG is on a distinguished road
Default Straightkey or Keyer/Paddles
I dont know what a Rc 2980 is but I would recomend starting with a Straight Key 1st,learning to send good code with that first,use it as you practice learning the code.The keyboard might be fine after you are licensed if you want to go that way.
The MFJ keyer is the way to go it has audio output that you can hear as you send and will work with a sk or paddle.Look for a J-38 SK,and the Bencher paddles are fb too,you should be able to find both for under $ 100 at a ham fest or other.Good luck also shoud be no problem hooking it up to your rig,probably a plug change or an ADAPTATOR will wrk fine.
DE-K8PG Paul CW LIVES :usa
__________________
I ONCE WAS A WORK BEAST
NOW I AM A BRAIN MERCHANT
JACK LONDON
  #5 (permalink)
Old 09-26-2006, 12:35 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
I agree about starting with a straight key. Learn to MAKE the characters sound they way they're supposed to, not just wiggling your thumb and fingers and having a machine do it for you. Learn to make the same sound -- the EXACT, PRECISE same sound -- as you hear on whatever code-learning system you might be using.
THEN, when you get up around 15 WPM with the straight key, consider going to a paddle and keyer. You'll know what things are supposed to sound like because you've learned how to make them manually.
IMO, for a beginning code student to use a paddle and keyer is like someone who's never tried sculpting to take mallet and chisel to a block of expensive marble and expect a masterpiece to show up, somehow. He first should learn the various techniques, and how to form the finished product.
Maybe not the best analogy, but I think you get the idea. Good luck!
__________________
No trees were harmed in the sending of this post; however, many electrons were inconvenienced.
73 de K7KBN
  #6 (permalink)
Old 09-26-2006, 02:14 PM
Senior Member
Default
Good stuff guys. Thanks... I will start the hunt. Keyer and straight key it shall be then.
__________________
www.cphilip.com
  #7 (permalink)
Old 09-26-2006, 05:29 PM
Senior Member
doctor is on a distinguished road
Default code
The guys are right, straight key to start with, and if you want to save more money, buy a straight key and since you own a computer go to
http://www.morsecodeonweb.homestead.com
download cwcom, and you can practice all you want hearing the tones, and when you get real ambitious you can talk to fellows and dont need a license. practice all you want, key plugs into an adaptor on your computer adaptors I believe are advertised there, and until your key arrives you can use the up/down key.
doctor :shock:
__________________
WAVING A HAND FROM CORNFIELDS OF INDIANA..HAVE A GREAT DAY
CDX 795/CEF795
QSL11.COM
Member...REACT INTERNATIONAL
  #8 (permalink)
Old 09-26-2006, 09:35 PM
Senior Member
Default
Thats cool stuff doctor. I think I will start out with that MorseKOB program and get set up for that. I mostly have all Mac computers but I do indeed happen to have a decent Windows laptop that I do keep out in the Shop so will start by downloading it to that and go about getting the proper inputs for that practice program.
Thanks for the Rx doctor (multiple puns intended!)
__________________
www.cphilip.com
  #9 (permalink)
Old 09-27-2006, 08:14 AM
Senior Member
Default morse
That morse kob program is for american morse and the cwcom is for international morse<ham>, I myself use both. The american morse is shall we say Railroad telegraph.
I belong to the Morse Telegraph Club and use on landline a sounder with a straight key into a morse converter and modem, where you can dial up a free HUb and talk to fellows using american morse, although I have talked to fellows using international code on it.
The units are furnished thru MTC at a lend/lease cost as long as you belong to the club. The sounder you have to get on your own.<140 ohm or better>.
Look for you somewhere along the morse route...
doctor :shock:
http://www.webspawner.com/users/dx700
__________________
CDX 795/CEF795
QSL11.COM
  #10 (permalink)
Old 09-28-2006, 05:43 PM
Senior Member
Default
What about the MFJ-557 practice keyer? Any thoughts on that unit. Appears meant for just this sort of thing. Straight key but with its own audible and even headset capable. And best of all, new its only 40 bucks.
http://www.mfjenterprises.com/produc...prodid=MFJ-557
__________________
www.cphilip.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
