Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Digital Modes Discussions
Amateur Callsign Lookup
Enter Callsign:
Calculating dial frequency
Reply
  #1
Old 02-06-2008, 05:32 PM
Senior Member
moleculo has disabled reputation
Default Calculating dial frequency
Lately it seems that I've been answering questions about how to determine the dial frequency when using frequency shift modes w/ a TNC (rtty, amtor, pactor, etc.) Here is a good website that has a calculator to do it for you and a brief explanation
http://kn4gc.us/dialcalculator.html
Here's the math, if you want to do it yourself:
For LSB, take the starting frequency + TNC Center frequency.
For USB, take starting frequency - TNC center frequency.
Some TNCs have fixed center frequencies that you can't change. Some (most) don't have a "center frequency" value, but have a "mark" and "space" frequency value, in Hz. In this case you must calculate the center frequency. This is accomplished as: (space + mark)/2.
Hope this helps someone.
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
