WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Amateur Radio Related > Digital Modes Discussions
Notices
This is the place to discuss and learn about all the interesting digital modes: SSTV, PSK31, CW, Pactor, Amtor, RTTY, etc. This section is for those who enjoy or are interested in CW and Digital Modes.
Reply
  #1 (permalink)
Old 04-07-2008, 08:06 PM
Senior Member
W5LZ is an unknown quantity at this point
Default APRS
Maybe I shouldn't say anything about this, it's sort of addictive. But, it's fun too.
I got interested in APRS because the local club and EOC were doing it. So, figured I ought'a too. After asking lots of questions, getting a sort of standard, "Ask _ _ _ _ about it, not me.", I asked whats-his-name about it. His reply was to get a program called "UI-View", something called "AGWE", and a map program, either an old version of the Delorme 'Street Maps' or one by 'Precision Mapping'. Figured that ought'a be easy enough.
Well, it was sort of easy, and then it was sort of "What the #3$$ did he say?".
First problem.
The older Delorme programs are off the shelf now. Plenty of new ones, but they don't work.
Huh.. Okay, find the old one. Yeah, right. But then I found a thingy on one of the APRS sites that sort of turned the new version 8 into the old version 7. (The 8 to 7 thingy isn't just one step backwards, it went back several years.)
Anyway, downloaded it, got it to work.
Now set up that 'AGWE' thingy which turns your computer's soundcard into a TNC. Okay, got it, ran it... "What the #3$$ does THAT mean!?", time.
Oh... guess I should hook a radio up to it, right? Okay, rob cord from over there, plug it into the speaker on the radio, plug other end into the soundcard input (knew where that was), dial in 144.390 on the radio... 'nuthin happening. OH! I see, gotta run both programs at the same time, gotch'a. Few hours later even got a few stations on the map, making progress!
Says you can connect to an APRS Server on the internet. Okay, I'll try it. Where to I find the URL? Finally found -them-, not -it-, but -them-. Huh... which one? What the #3$$, try'em all.
You/I have never seen so many @#$ stations... covered the whole map of the USA. Several layers deep! Huh, it says something about filtering, wonder how that works. Guess I ought'a read the @#$ instructions to start with instead of just 'winging' it.
To make a looong story short, I got it working at the house. The laptop is/was a different story cuz it uses that @#$ Vista! Found a way to do it, it really does pay to read those "FINE" manual. Got the laptop to work okay with only one problem. It (Vista/laptop) doesn't like the radio in the truck. Works fine with a scanner, just not the radio. Okay, I'll just use the scanner. Crap, need another antenna... Got two on the truck for regular two meter stuff and one dedicated to a separate APRS transmitter. Besides having to find a @#$ mount, I guess I could make one.
{Used the scanner at the EOC connected to an unused antenna at the 100 foot level on the tower. Little bas**** was hearing Dallas! No idea what the antenna was designed for (who cares), but it works well with a scanner!}
After some more noodling around I found a non-free program to take the
'AGWE' program's place. Same guy wrote it, just charges for it since it does it's own thinking instead of me having to do it. Worth the price! It's also a commercial program so much more idiot proof than the other one. When I registered it he found out I was a ham (he's SV2AGW, Greece) and threw in a free registration for a second computer and something else I haven't quite figured out yet.
This $#^+ is FUN! You ought'a try it. The only thing I'd really, really recommend is to RTFM first, not later. Saves a lot of grey hair, but then, mine's already grey, so big deal...
  #2 (permalink)
Old 04-08-2008, 06:15 AM
N9RZD is on a distinguished road
Default
i remember when packet was a huge message handling network and lots of local qso's going on,
i handled dozens of health and welfare messages for local people during the first gulf war , when you could send a message halfway around the world and get a response back within twelve hours ,
internet killed that ,
and now its just used to update your position on plane earth in real time ,
why would i want to let people know where im at all times ???
dont mean to sound cynical, i just dont understand why aprs exists ???
73 de rich
  #3 (permalink)
Old 04-08-2008, 08:11 AM
Senior Member
Default
Rich,
I'll bet you can think of a few reasons why something like APRS would be handy. Of course, that just depends on what you happen to be doing. The storm season here is a fairly good example, as in just where are those storm watchers anyway? Or, I seem to have misplaced my truck. Wonder where it went? Or, who knows what else? Not a lot of -important- stuff, just stuff, you know? Besides, you ever get that feeling that if old whats-his-name can do it, I certainly ought'a be able too, kind'a thingy?
'Cynical'? No man, you just haven't reached the 'right' state of mind yet.
And besides... I ain't happy unless I've got something to 'whine' and complain about.
  #4 (permalink)
Old 04-28-2008, 07:19 PM
Registered User
JK_RUBICON is on a distinguished road
Default
  #5 (permalink)
Old 05-07-2008, 02:22 PM
Senior Member
Default
Just some more stuff that'll probably bore you to death...
Ran across an 'add-on' to the "UI-View" APRS program that can tell you the effective range of your antenna set up. It's called "UI-Aloha". Get all the other stuff running correctly then add this thingy to the UI-View program directory. After a little time to receive stations, it does some calculating and draws a circle around you on the map. That's the 'effective range' of what you are hearing (RF, not internet). And since your transmit range is basically the same as your receiving range, it can give you a sort of 'ruff' idea of what your set up is capable of. Heavy emphasis on 'ruff'! It also depends a great deal on propagation, so sometimes it'll be unbelievably good. I have a hard time believing that I can be heard on the Texas gulf coast with an antenna maybe 15 feet high. On the other hand, though, I do hear a few APRS mobiles at that far a distance, so I guess it's possible. Who cares, it's fun to play with...
(Do a search for 'UI-Aloha' and you'll find it.)
  #6 (permalink)
Old 05-13-2008, 12:21 AM
cyclops1970's Avatar
Gay Nazi Liberation Party
cyclops1970 is on a distinguished road
Default
Quote:
73 de rich
I'm right there with you, friend. I once sat in a guys APRS decked out mobile with laptop, GPS, and 2 meter as he ran the system thru it's paces. I asked him "So why is this better than calling you on the radio and asking "What's your position" and you looking at your GPS and saying "I'm at 43.28 north by 98.35 west".
He looked at me like I had just kicked his dog.
But to each his own....as far as effective range goes, I use Radio Deluxe. It's a pain to D/L all the SRTM coord sets needed, but as far as accuracy goes, it's on par with so-called "Professional" software packages.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
