| | | Notices | Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar. | Digital Modes Discussions  This is the place to discuss and learn about all the interesting digital modes: SSTV, PSK31, CW, Pactor, Amtor, RTTY, etc.
This section is for those who enjoy or are interested in CW and Digital Modes. |  |
06-09-2008, 02:23 AM
| | Member | | Join Date: Oct 2005
| | cocoamodem and psk31 -- getting closer to going digital!! i am interested in using cocoamodem (or a similar mac alternative) to learn more about psk31, and maybe give it a try.
at present, i have no experience with digital modes (or CW), and psk31 seems to be the mode that everyone is talking about, so if anyone has a wealth of knowledge that they could possibly pass on?, please do so!
while i am interested mainly in cocoamodem and macintosh software, perhaps someone has some information, that i may be able to use -- even windows-based info. as it applies to my learning more about psk31.
thank you!
73, Snake Eyes |
06-09-2008, 04:23 AM
| | Senior Member | | Join Date: Jun 2006 Location: Staunton, Virginia
__________________ IC-756 PROII
IC-SP23
IC-PS125
Palstar AT1KP Antenna Tuner
Rigblaster pro
IC-2200H
SM20 Microphone
MD-100 Microphone
Yaesu FT897D
IMAX 2000
Inverted "V' Diploe
4 element 2 Meter beam and Rotator
Astron SS25 |
06-09-2008, 08:09 AM
| | thank you KI4MSJ.
73, Snake Eyes |
06-09-2008, 08:38 AM
| | Senior Member | | Join Date: Apr 2005 Location: Oklahoma
| | Snake Eyes,
I've no experience with 'Mac's so take this for what it's worth. I do have some experience with 'Windows' based stuff so will tell you a little about that aspect.
Most of the 'digital' modes can be done without a modem of any kind. Basically, all you need is a sound card in the computer, and a means of connecting that sound card to the output/input of a radio. Software 'modems' are fairly common, sort of.
The biggest problem is making the computer and radio 'compatible', getting rid of, or stopping any RF interference. Quite a few of those thingys on the market now, and not all that difficult to make if you feel like it.
Just to see if you might like PSK31, or several of the other modes, try finding the applicable software, install it, get an audio cable to connect the output of the radio to the input of the sound card (speaker on the radio, mic/aux/whatever input on the sound card). Listening is pretty easy. Transmitting doesn't have to be that easy, one or two 'gadgets' to put in line, sort of.
Biggest difference between the sofware programs is the user interface, the 'control panel' you look at on the screen. Some are 'nicer' than others, just depends on the individual. The basic programs all 'do' the same thing, basically.
Try it, you'll like it...
Bunch not said in the above! Untill you find that you want to 'do' this stuff, why go to the bother? Sort of... Oh #3||, why not! |
06-09-2008, 11:19 AM
| | Senior Member | | Join Date: Mar 2007
| | Yeah you need
1) audio in and out of your rig, to and from your computer
2) psk software to run on the computer
3) a means to PTT/ TX your rig
The PTT part can be done via serial port of the PC, you can use the audio and VOX built into the rig already (I don't recommend that), or you can use pre-made interfaces that do it a few other ways.
My favorite of my three, a homebrew, a Digimaster Duo, and a Tigertronics Signalink USB, is the Tigertronics. |
06-12-2008, 04:41 PM
| | I am in the midst of working with another ham, to get on digital VHF, most likely on PSK31. We are not quite ready to take the "digital plunge" as of right now, but are working on getting the right hardware, some of which we already have.
Thanks for your help guys!
73, Snake Eyes |  | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 09:06 PM. |
