Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Digital Modes Discussions
Notices
This is the place to discuss and learn about all the interesting digital modes: SSTV, PSK31, CW, Pactor, Amtor, RTTY, etc. This section is for those who enjoy or are interested in CW and Digital Modes.
Reply
  #1 (permalink)
Old 09-27-2008, 11:25 PM
KA5ROW's Avatar
Junior Member
KA5ROW is on a distinguished road
Talking "GOOD" interface to use for digital
Recommendations for a "GOOD" interface to use for digital, mostly SSTV.
(Good not Cheep)
Timewave, Rigblaster, Tigertronics You tell me.
__________________
Matthew 24:27
For as the lightning cometh out of the east, and shineth even unto the west; so shall also the coming of the Son of man be.
http://www.ka5row.com
  #2 (permalink)
Old 09-28-2008, 04:04 AM
Senior Member
W5LZ is an unknown quantity at this point
Default
Doug,
Depends a lot on what you will be using it with, computer, programs, and radio. Some manufacturers make things a bit easier with specific brands, not difficult, but not exactly easy with others (that's mostly with the software and computer, sort of).
I have had one of the older 'RigBlasters' since it wasn't old at all. It works fine. Because of the trend away from Serial port to USB port control, I've had to up-date a driver or two, but all things considered, not a biggy. The biggest 'problem' with the 'RigBlaster' stuff is that it's not cheap. The only 'firm' suggestion is to stay away from the "no-mic" versions no matter who makes them, just really aggravating.
If you don't mind building, an SSTV interface isn't that difficult to make, usually works with other digital programs, and will keep you occupied getting the 'bugs' out of it (also normal).
I've been 'away' from SSTV for a couple of years so can't say I'm familiar with all that's available now. 'Timewave' used to make some very good DSP stuff, didn't know they were into interfaces, might be a worthwhile thingy to think about. I've heard a lot about 'Tiger', but not directly related to SSTV. I'm trying to get used to sound card based TNCs and interfaces (lap tops) so my knowledge is 'dated' for the other kind of thingys. Good luck! (You do know that SSTV stuff is addictive, right?)
PS - Been tempted to jump off that 'mountain' you got down there a few times. One thing and another, never have (that's called chicken, by the way) . If you should happen to be extremely bored some second Thursday of the month, come on up and take in one of our club meetings (W5CUQ.com), find out all the things you should (and shouldn't) do/know. The 'trick' is figuring out which is which...
  #3 (permalink)
Old 09-28-2008, 10:44 AM
Senior Member
moleculo has disabled reputation
Default
I have a RigExpert Standard to interface with my Icom 706mkiig and also Yaesu 897d (you have to buy or make different cables for those two rigs). It has a USB interface and also gives you an extra serial port on the interface in case you have something old like a TNC you also need to use. It works well, although I can honestly say that I've had to tinker around with settings quite a bit in MixW to get it to work consistently. This has to do more with the sound driver it installs than anything else. It does seem to be a pretty good, small form factor device.
I also built one myself for my Icom 746Pro. I use this several times a week on a few different digital modes. It's really easy to build a sound card interface to the line in/out on your soundcard and only costs a few dollars. For the rig control, I purchased a $20 CAT cable for the rig. I think the whole interface cost me $30, including the CAT cable. The only reason I didn't just go this route with the other radios is because I have a specific use case for the 706 that wouldn't let me do this and since I had already purchased the RigExpert to satisfy that use, I decided it was just easier to buy the additional cable to make it work with the Yaesu.
  #4 (permalink)
Old 09-30-2008, 05:02 AM
N9RZD's Avatar
Freon Cowboy!
N9RZD is on a distinguished road
Default
I built my own for about thirty bucks
http://www.geipelnet.com/barry/PSK31.pdf
works well ,
  #5 (permalink)
Old 09-30-2008, 08:46 AM
Senior Member
SR385 is on a distinguished road
Default
I have a home brew, a Digimaster Dual and a Tigertronics Signalink USB.
The Tigertronics is the best.
Has its own soundcard so you can move it from computer to computer which is very convenient.
Does its own keying through an electronic VOX circuit so making cables for a few rigs is very simple to do.
Requires no power to run, runs off the USB.
There is a waiting list so order soon ;-). It's worth the wait.
  #6 (permalink)
Old 09-30-2008, 12:30 PM
Supporting Member
Highlander_821 is on a distinguished road
Default
works well ,
And the one that N9RZD built for me works great. Just had a SSTV exchange with a fellow in England on Saturday using this homebrew box.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #7 (permalink)
Old 11-19-2008, 08:38 AM
hookedon6 is on a distinguished road
Default
i have never had any problems with my BUXCOM interface... cheap too
  #8 (permalink)
Old 12-07-2008, 06:59 AM
richie is on a distinguished road
Default
ive been using the rig blaster plus for about 3 years, it does a great job, easy to setup and use ...........another plus is that it is easy to re-set the jumpers inside for almost any radio from a simple cb to an old valver
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
