I think it probably was the maps I was having problems with. I'll have to see if I can find the instructions again and try once more.
I almost wish I had a spare 2m rig and antenna that I could just run this stuff permanently on. Actually, I do have a spare 2m/440/6m antenna, but I'm running out of places to put antennas
If it is the maps thingy, there is a 'work around' for that. It still means you will probably end up having to buy a 'map' program unless you happen to have a very old 'map' program, and I can't think of the name of the older program right now.
There's a 'patch' for what's called 'Maps -7', which works just fine with the latest version of that thing called 'Maps-8'. Talking about something around $50. That map program is very good by the way. Oh well...
