Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
rci2970n2 bias help
Reply
  #17
Old 06-05-2011, 04:42 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Posted By DXMan:
Quote:
Many of the N2 were coming out doing 300 watts (I also heard of one that was doing close to 400)- but this does mean that they were rated at 300.
Have you tested any of the 2nd version's yet? I have heard of several now that are coming out of box doing around 215/225 - which is what they should be doing.
I had mine retuned from the factory 300 watts down to 215, I am now running it on a 36 amp P.S. - draws 18 amps on SSB (which is what the manual states it should draw).
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #18
Old 06-05-2011, 06:23 PM
cbkidd1's Avatar
Senior Member
cbkidd1 is on a distinguished road
Default
Thank you jeff for taking the time to help me. Maybe someone with more knowledge will step in and give me the right voltage for the irf520. You know i can not find the service manual for the ept-695015a board.Maybe rci just have not put it out yet sure would be a big help.
  #19
Old 06-05-2011, 06:46 PM
Default
Have you e mailed Ranger to see if they can advise?
__________________
Radio-active
NASA/SOHO
  #20
Old 06-05-2011, 08:09 PM
Senior Member
DXman is on a distinguished road
Default
From what I've found out was; the first production N2's were coming out with the "gate voltage" to high, this was causing the failure of the Mosfits. Guys were seeing 300 watts with a 50-60amp draw.
So after I found this out, I then sent mine into DTB radio for his complete alignment/tune. I explained what I had found out and to check the "gate voltage" and set to radio to do no more than 225 watts with roughly 18 amp draw.
Well the radio came back doing the 215-225 watts and 18 amp draw which was prefect for me. Now the radio is running cool and I am using just a 35 amp P.S..
The 2nd version is now working better than the first. From what I have been hearing, Ranger has gotten the wattage down lower (around the 200 watt mark) now and they seem to be doing better.
One more thing - I have heard of (2) of first series N2's blow up and sent back to Radio Active Radio for repair (which is where they were first bought and tuned), repair bill on one was around $200. This came right from the owner! So.......as we all know.......................................!!!
PS - I have no idea what the gate voltage is.
__________________
5 element Yagi since '76/I 10K since '09
208 DXCC - 11 mt. (183 DXCC with a 30 watt radio)
  #21
Old 06-06-2011, 09:02 AM
cbkidd1's Avatar
Senior Member
Default
I really appreciate all of you taking your time out to help me with the irf520 mosfet gate settings. I sure have learned a lot about mosfets in the last few days lol. Would i be right in saying rci should have used a power mosfet like a erf7530 or something close to it?
  #22
Old 06-06-2011, 09:27 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Hey, its what we do forums for.
No problemmo . . .
The ERF-7530 is mfd by the owner of Magnum radios, Sam Lewis/EKL components. In fact, all of the ERF-series MOSFET's are made by EKL. RCI/Ranger USA isn't going to buy EKL parts. That would be like Chevy buying their motors from Ford!
The EKL brand makes their devices specifically for RF applications. Most of the IRF-520 'x' MOSFET's are not built for RF signals and only one or two of them will work for RF apps. If you are going to replace a MOSFET device; I would stick to the EKL brand - IMO . . .
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #23
Old 06-06-2011, 12:16 PM
cbkidd1's Avatar
Senior Member
Smile
I emailed ranger tech support last week. And chip sent me all the info that they had right now regarding the rci2970n2. I hope this info will help others. I will let Jeff put this were he thinks it should go.
Sorry for the delay. They are still working on a service manual for this model.
The 2970DX manual can be used for alignment as it is the same with exception of the driver and final transistor alignment which is as follows.
Turn carrier and mic gain control on front to minimum.
Turn mode switch to SSB
Key transmitter and set the following voltages measured on the gate of each transistor
MAIN BOARD
Driver gate voltage 3.6VDC +-.1VDC
Final gate voltage 3.4VDC +- .1VDC
PA BOARD
Bank 1 VR-2 gate voltage 3.5VDC +-.1VDC
Bank 2 VR-3 gate voltage 3.5VDC +-.1VDC
Please note also same alignment as in service manual except higher wattage listed below.
Carrier should be set to no more than 100 watts at max power AM/FM
SSB should be set to no more than 200 watts PEP at max power SSB
Regards,
Chip
RADIO SHOP SUPPLY
RANGER USA PARTS & SERVICE
1672 Main Street Suite E #228
Ramona, CA 92065
(760) 440-0125
Hours 9am - 5pm PST Mon-Fri
  #24
Old 06-06-2011, 12:56 PM
Default
Thank you for posting the reply, I am sure it will help others that are looking for the same info.
__________________
Radio-active
NASA/SOHO
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bias design, amplifier design, filtering etc. -=PEAKABOO=- Amplifiers 132 11-27-2012 06:45 PM
RCI 2950 Bias Problem Robb General CB Services Discussion 10 03-10-2011 06:04 AM
142 bias stingray General CB Services Discussion 3 12-27-2008 06:48 PM
KLV1000 Drifter Amplifiers 14 03-22-2008 06:52 PM
high final bias current on 139xlr loosecannon CB Band and CB Radios 4 02-21-2007 06:23 PM
Powered by vBulletin®
