Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
President Grant or President Jackson...which is better if any?
Reply
  #1
Old 10-13-2011, 01:24 PM
70cst's Avatar
Senior Member
70cst is on a distinguished road
Default President Grant or President Jackson...which is better if any?
Is there any difference between Grant and Jackson? My main interest is AM capability...
Also what years were these radios made?
Which came first?
Thanks
  #2
Old 10-13-2011, 01:58 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
There both great radios so its up to you which you like better. I know the Jackson ran the Higher wattage MRF-477 but Im not quite sure what the Grant uses if its the same or not being its a new radio.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 10-13-2011, 02:19 PM
70cst's Avatar
Senior Member
Default
Quote:
I am guessing the Grant was made in the early 80's...I think--but I am not sure. If my memory is correct the Grant was made before the Jackson...possibly by different companies.
  #4
Old 10-13-2011, 02:21 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Quote:
Uniden chassis in either one.
Couldn't go wrong with either one.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #5
Old 10-13-2011, 03:09 PM
sp5it's Avatar
Master of puppets
sp5it is on a distinguished road
Default
Jackson have more narrower AM RX because of use SSB crystal filter in AM RX path. Dual clarifier can go from 0 up to +10KHz on TX/RX and separate fine clarifier knob for RX only. My choice beacause of AM RX performance.
Grant only with PCB PC-999 had dual clarifier, but not as wide as Jackson.
Grant has dual 2sc2312 final stage, can do NPC-RC and after that is AM audio monster doing up to 40 Watts on AM with about 170% of crystal crisp modulation and no flattops on the scope. I've done couple of them that way.
Jackson is low level AM modulation, but sounds great on TX anyway.
Of course you can "rewire" AM path in Grant to go thtough SSB crystal filter byt it is not that easy to do.
Mike
__________________
My pile-up breaker
  #6
Old 10-13-2011, 06:05 PM
davegrantsr's Avatar
Senior Member
davegrantsr is on a distinguished road
Default
go with the grant, better receive with dual conversion & as noted above, low level mod in the jackson on am.
of course it depends on what you're using the radio for, 5 bands vs 3 goes to the jackson, 10kc switch......bite the bullet & buy an ic7000
  #7
Old 10-13-2011, 06:18 PM
70cst's Avatar
Senior Member
Default
The application is-- the radio will be installed in my pickup. I want a good AM talker that was made in the in 70's to mid 80's. That is why I am looking at these two radios. I have a mint Jackson and I am in process of purchasing a mint Grant. I need to decide which is the better radio for my application.
Thanks for your feedback.
  #8
Old 10-13-2011, 08:42 PM
70cst's Avatar
Senior Member
Default
This is the Grant that I will pick up next week ...
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
President line of radios Red Ranger Export Radios 104 02-28-2014 08:16 AM
President Jackson 2 Modulation modification AudioShockwav CB Radio Modifications 3 01-07-2013 08:35 AM
PRESIDENT/UNIDEN RADIO ADJUSTMENTS AudioShockwav CB Radio Modifications 0 07-24-2011 03:01 PM
President Grant DX : PLL Swap Terrster Export Radios 0 12-13-2010 04:51 PM
Whats the Difference the Uniden Grant (looks like a President Grant) & the Grant XL 70cst CB Band and CB Radios 13 02-16-2010 06:12 PM
Powered by vBulletin®
