Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Does a 2950dx need a swing kit?
Like Tree1Likes
Reply
  #9
Old 12-02-2011, 12:52 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
There is nothing wrong with a swing mod for AM - provided it is done right and the operator uses it correctly . . .
Don't cut the limiter. If the limiter is cut along with doing the NPC swing mod for asymetric modulation; then either have a tech set it up and do the work and make sure that the modulation doesn't square wave - or get a scope and do the work yourself.
The quality of this mod is all in the details; it is not just a matter of snipping some parts and putting other parts in.
It is about getting the right wave form from the swing mod. When done correctly, the difference can be amazing. If done wrong, it will sound like junk.
Either do it right - or not at all . . .
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #10
Old 12-02-2011, 12:57 PM
kd-5-bgt is on a distinguished road
Default
No to the swing kit....just as mentioned a proper tune and alignment...dont cut limiters.And use a good shop to do the tune,leave the truck stop bandits alone
The 2950 is a great SSB rig out of the box with the basic 11 meter mod done,I had one a while back and just run SSB with it and loved it !! Got good reports on audio quality with a stock mic.
Robb hit the nail on the head!!
  #11
Old 12-03-2011, 11:37 PM
Senior Member
9C1Driver is on a distinguished road
Default
As stated the 2950 is great with just a proper tune and alignment. That said I heard a 2950 on the air that Richard at 8541 electronics set up with the SP-1A speech processor, wow loud SSB talker. I have also heard that the CP-1 compressor made by top gun also helps out on SSB. If your going to buy the radio from Doug just give him a call and he might have a good idea of what to do or not to do.
  #12
Old 12-04-2011, 11:18 AM
Senior Member
JoeDirt is on a distinguished road
Default
Robb's right, If the swing kit is properly done its worth it. I dont trust anyone doing a swing kit on my radios. I also have yet to see a radio from a tech that has installed the swing kit the right way! (by checking there work on a scope after there done)
If I was you just give it a tune-up and call it good!
  #13
Old 12-04-2011, 01:56 PM
psycho's Avatar
Supporting Member
psycho is on a distinguished road
Default
Quote:
Originally Posted by undertaker View Post
This radio when i get one will be 99% side band. I see custom cb radios installs swing kits with his peak and tune.
Thanks
Bobby
An npc mod with the 2950's variable will allow you to use amps that work good with different dead key input wattage requirements.
If you are going to use the radio 99% for ssb, why would you even care about AM anyway?
__________________
Just when you think things couldn't get any worse, the news comes on.
  #14
Old 12-04-2011, 03:48 PM
undertaker's Avatar
Undertaker
undertaker is on a distinguished road
Default
Well I just ordered one from Bobs cb so I know it will be all good....
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
midland 75-822 swing kit? akforlife General CB Services Discussion 6 03-04-2013 06:20 PM
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 190 02-15-2012 07:54 PM
VARIABLE POWER w/ Swing Mod Kit Cobra 25 29 Uniden ( NOW SHIPS TO CANADA ) Ebay CB Radio Gear eBay Auctions Ending Soon 0 11-25-2011 03:12 AM
AM CB Myths??? Simbalage22 CB Band and CB Radios 52 11-19-2011 07:15 AM
29 swing kit stingray General CB Services Discussion 8 03-26-2009 02:39 AM
Powered by vBulletin®
