Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
AR-3500 HELP!!!
Like Tree1Likes
Reply
  #1
Old 02-22-2013, 05:12 PM
hacksaw's Avatar
Senior Member
hacksaw is on a distinguished road
Default AR-3500 HELP!!!
I just bought this sweet looking AR-3500. It's the 30 watt version. It is smoking clean! Very clean case, almost brand new looking face, 8 pin mic plug, factory installed SP-1 processor, and scan board for a factory Palm Scanner mic. All MINT! I'd say its a 9 out of 10. Still has the factory sticker on the top cover for warm up info. No bracket, but it has the factory power plug. Verg radio except for 11 meter coverage. When power is removed it resets back to 26.000.0. All buttons work perfect, all knobs work smooth. I don't think the NB/ANL is working and I noticed some fluttering audio at full RF gain with the heavy skip this evening. Have to roll the RF gain back to 12 o'clock position. Then it clears up the receive. I made a contact last night on lsb and he could hear me 20 miles away but said it sounded rough. And I observed a swing around 15 watts. As far as it looks its never been tuned or probably aligned. Diodes and resistors are all in tact. No cutting in this rig!
So, where should I start? This is a fine piece!!! Thanks
  #2
Old 02-23-2013, 05:55 PM
davegrantsr's Avatar
Senior Member
davegrantsr is on a distinguished road
Default
it's junk. i'll give you a hundred bucks for it
the battery is dead, that's why it resets to 26.0
i'm not home so i can't check, but look for the 3500 manual with the factory updates & make sure they are all corrected. they fix the delay when you unkey the mic in ssb, they correct the 'too much receive gain' issue you describe, and by fixing all the grounds you resolve the 'low swing/rough audio in ssb' i'm guessing you have.
i'm on 4040's watergate somewhere exhibiting the audio issue you have....if i could only find which gate. it was on nov 10, 2011
contact with 4040
  #3
Old 02-23-2013, 07:02 PM
hacksaw's Avatar
Senior Member
Default
contact with 4040
Thank you so much! That's the best Wes I've heard all day. I actually posted this radio along with an Emperor TS 5010 for trade into a Magnum s9hp but I'm still debating on keeping this radio. It's beautiful!
  #4
Old 02-23-2013, 10:34 PM
KingCobra_CDX882 is on a distinguished road
Default
Once you Get your AR-3500
Set up Properly..
Few radios work as well.
It has Great Ears as well as a Really good sounding SSB radio.
Even Most of todays HF ham rigs do not out perform it
( i used to have the 100 watt version of the AR-3500 )
Only my IC-7000 had Slightly better ears
(as good as my 706 MKIIG )
  #5
Old 02-24-2013, 05:16 AM
Senior Member
seedkey is on a distinguished road
Default
someone must have the answer. to these ar3500 problems
  #6
Old 02-24-2013, 05:29 AM
Senior Member
hotrod is on a distinguished road
Default
a gotta ranger 3500 -30 watt version that needs a protection diode .
would bobscb still have any?
__________________
BASE-magnum delta force, emperior 5010, AR 3500, sirio 2016
MOBILE-ss3900, uniden grant xl, z180, 636lS.E.
  #7
Old 02-24-2013, 06:15 PM
70cst's Avatar
Senior Member
70cst is on a distinguished road
Default
I recently sent two AR3500's 100w models to CB Bobs for a complete tune up and updates. He should have the parts that you are looking for.
KingCobra_CDX882 likes this.
  #8
Old 02-24-2013, 06:44 PM
hacksaw's Avatar
Senior Member
Default
Quote:
I emailed him asking about my radio and never got a response
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
AR 3500 30 watt verses the 200 watt 70cst Export Radios 4 11-09-2012 09:02 PM
Ranger AR 3500 WANTED!!!! w4bss CB Radio Gear SwapShop 1 07-12-2012 07:16 PM
RANGER 3500 TonyV225 Export Radios 26 01-10-2010 07:16 AM
Palomar 3500 TonyV225 CB Band and CB Radios 4 05-06-2005 09:59 AM
AR 3500 driverdude CB Band and CB Radios 3 12-26-2004 12:35 PM
Powered by vBulletin®
