Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Old school president Grant DX PC 999 board
Like Tree1Likes
Reply
  #1
Old 03-25-2013, 09:03 PM
Senior Member
Staybolt is on a distinguished road
Default Old school president Grant DX PC 999 board
Are there any swing mods or an NPC mod that can be done to the Grant Export?
  #2
Old 03-26-2013, 02:22 AM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
Why would you want too?
of all the ssb export radios Uniden/President made the Grant has the nicest punchiest AM of all (imo), you could listen to someone talk on a Grant all day and never tire of its AM tx audio.
Swing mod,what for,set it as close to 100% modulation as you can with an 8 watt carrier and watch that baby swing to almost 32 watts with very little if any distortion from those matched pair of 2sc1969 or 2sc2312's.
Not sure if you guys had a single final version Grant,I'm sure you did and I'd expect it might even out compete the export versions, having never got hold of one I can't be sure, but if I recall it was the same board as the legendary cobra 148 gtl.
Why destroy such beauty ?
__________________
"IT WON'T BE EASIER TO SPREAD YOUR VERSION OF HOW SH*T TICKS"
BOB85-2010
  #3
Old 03-26-2013, 02:44 PM
Senior Member
Default
Bump bump
  #4
Senior Member
Default
[QUOTE=jazzsinger;419654]Why would you want too?
Because I want to......
  #5
Old 03-26-2013, 04:07 PM
sonoma's Avatar
Senior Member
sonoma is on a distinguished road
Default
you have not said what PLL is in your grant. if it is the 858 PLL here is all the mods that are available for it on radionuts sight. there is not a lot because it does not need much if it is the 858 PLL.
uPD858 Chassis upgrades and modifications - CLICK HERE!
  #6
Old 03-26-2013, 06:32 PM
Senior Member
Default
Please reread my post.......
  #7
Old 03-26-2013, 07:23 PM
sonoma's Avatar
Senior Member
Default
I read your post before I put the link to radionuts sight. I asked what PLL it has in the radio. also I told you this is all that can be found on the radio you have unless it has another PLL in it. I have a friend that has been repairing radios at his shop for over 40 years and he does not know of a swing mod or NPC mod you asked for. he said the radio is about as good as you can get it. it should have good swing and audio as it is unless there is some bad electro caps in it , such as 10 volt caps get weak at the age of your radio.
  #8
Old 03-26-2013, 08:15 PM
sonoma's Avatar
Senior Member
Default
I finally found a pc999 schematic. it shows your radio to have a 8719 pll. without having a picture of the circuit board to see the layout. I looked at the schematic and if you lift the leg of r279 the right one and put a 1n4001 in series with it should give you more swing. looks as if it would lower the dead key and swing more.put the cathode end in the open hole you pulled one leg of r279 out of. solder the diode and resister together at the top. its worth a try. not responsible for any problems you may incounter doing the mod. I am not aware of your experiance with radio mods. which I feel is not much since you are asking what to try.
this should work simular to the galaxy R238 diode mod.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
President line of radios Red Ranger Export Radios 104 02-28-2014 08:16 AM
PRESIDENT/UNIDEN RADIO ADJUSTMENTS AudioShockwav CB Radio Modifications 0 07-24-2011 03:01 PM
Whats the Difference the Uniden Grant (looks like a President Grant) & the Grant XL 70cst CB Band and CB Radios 13 02-16-2010 06:12 PM
The ARRL Letter Vol. 27, No. 4 February 1, 2008 AudioShockwav FCC & ARRL Activity 0 02-01-2008 04:49 PM
Mag delta force problem.. Splash1 CB Band and CB Radios 9 02-03-2007 12:49 AM
Powered by vBulletin®
