Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Galaxy DX2517 extremely low power
Reply
  #1
Old 03-28-2010, 09:01 AM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default Galaxy DX2517 extremely low power
My Galaxy DX2517 has developed a problem on TX. I can get the radio to key on AM, FM, and SSB modes, but only a very, very tiny amount of power results.
Not even the slightest indication on a 5 watt scale meter. The radio indicates that it is modulating, and it can be monitored on another radio ( I can hear the audio). I was running SSTV when it happened, or just before it happened.
Ater testing SSTV transmit and receive, I disconnected everything to try to neaten up the wiring and all, and when I got everything buttoned back up, I went to transmit SSB voice with my mic and discovered that all of a sudden I have almost no power!
Any ideas? I wonder if I put too much audio from the soundcard into the microphone circuit... Could that possibly start a chain of events that could lead to this failure?
Thanks for any thoughts or advice at this point.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #2
Old 03-28-2010, 09:04 AM
Amour d'Ecosse
Default
Ooops! sorry for the double post!
__________________
  #3
Old 03-28-2010, 09:40 AM
pro151's Avatar
Supporting Member
pro151 is on a distinguished road
Default
Quote:
Your fired! Turn in your mouse and clean out your locker.
__________________
MASTER TROLL
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
  #4
Old 04-22-2012, 04:27 PM
liquidh8's Avatar
Senior Member
liquidh8 is on a distinguished road
Default
I have a saturn that just started doing this.
  #5
Old 04-22-2012, 05:00 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Check the bias settings on the finals. Either those bias diodes are gone and it won't bias; or the final transistors are gone. If it was a modulation problem; then AM still should show proper dead key power. From what you have said - it doesn't. The reason you still see some power out, is probably because the driver transistor is still working.
http://www.cbtricks.com/radios/galax..._trans_adj.htm
http://www.cbtricks.com/cgi-bin/database/galaxy_db.cgi
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #6
Old 04-22-2012, 06:06 PM
Senior Member
9C1Driver is on a distinguished road
Default
Quote:
Were you running SSTV as well?
  #7
Old 04-23-2012, 05:52 PM
liquidh8's Avatar
Senior Member
Default
Thanks for the links. Ill have to get it to do it first. I can talk on it for a while and all is good, then all of a sudden, nothing. After I turn it off and it cools down, then it is good again. the driver and finals are new from a few months ago.
  #8
Old 04-24-2012, 03:15 PM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
Quote:
that's very possible and most probable, but also possible is a missing/low tx mixer signal, could be the low output isn't even on 27 mhz, (very hard for a tuned output stage to amplify an out of band signal as efficiently as an inband one) power meters ain't smart enough to tell, but a frequency counter inline with it might,
this was actually seen by a friend on a magnum 257 that had both driver and final working but still low output, no reason it couldn't happen on any other uniden clone. caused a few people a lot of head scratching, always worth checking the oscillator signals are present, before you assume the rf amp is fooged.
time to get a scope and freq counter out.
__________________
"IT WON'T BE EASIER TO SPREAD YOUR VERSION OF HOW SH*T TICKS"
BOB85-2010
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Galaxy 95T2 Review Robb Export Radios 10 12-12-2009 03:52 PM
galaxy DX88hl, low power jbenally33 General CB Services Discussion 3 04-04-2009 08:41 AM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 08:16 PM
variable power on eagle 2000 aka galaxy saturn missouri 69 General CB Services Discussion 1 12-30-2003 09:25 PM
Powered by vBulletin®
