Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Converting a President HR-2600
Reply
  #1
Old 05-30-2010, 10:23 AM
mechanic's Avatar
Senior Member
mechanic is on a distinguished road
Question Converting a President HR-2600
I found a decent 2600 at Dayton two weeks ago and got it working, since it is not easy to convert and a Chipswitch may be a tough find, I though I would ask opinions about a mod I have in mind....
One of my "waiting to be repaired" 2510s has a major fault on the RF board with the receive but the rig transmits fine, is on frequency and tunes across the band it covers....
My idea is to swap the microprocessor board and the display with the 2600, seems that all the wires are there and I could wind up with a good rig this way! There seems to be minor differences between the RF boards but not too many. I wonder if this hybrid would work....
73 mechanic
  #2
Old 05-30-2010, 09:56 PM
Quiksilver's Avatar
Senior Member
Quiksilver is on a distinguished road
Default
You might find some info at this link.
Rogerbird's Radio Modification Information Page
  #3
Old 05-31-2010, 05:12 PM
mechanic's Avatar
Senior Member
Default
Thanks Quicksilver! I can use some of the info to compare the rigs and they look pretty darn close. Before I commit to the mod I want to research them to the fullest so I don't "kill" them!
mechanic
  #4
Old 06-04-2010, 12:21 AM
Senior Member
Rogerbird1 is on a distinguished road
Default Swap
Actually,
The better mod would be to remove the 2510 microprocessor and the 2600 micro, and install a socket in the 2600 and then use the 2510 micro in the 2600.
It will work (done a few this way). You still will have to add the 11 mtr mod to the 2600 (the same way you do a 2510). But the micros are the same with different programming in them.
The displays are the same (exact same) and the main board in the 2600 is the improved version of the 2510. (with all the circuit updates)
The Micro boards are not drop in replacements, the 2600 has different plugs and jacks, It can be done, but you have to figure out which wires you need and which you dont.
Also when the chipswitch is available again, you just pop it in, no need to remove the conversion mod. (still hoping to get some chipswitches in the future).
If you are careful or know some one that is handy with a soldering iron and de-solder tool, this isnt that much of a job.
I could do it for you if you want.. Email me.. Rogerbird1 @ aim . com
Roger
  #5
Old 06-04-2010, 11:07 AM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Roger Pm me your address and phone number I have a few 2510 I need you to fix or look at atleast
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
President 2600, is it a Good radio? Rogerbird1 CB Band and CB Radios 2 04-27-2003 04:31 PM
Powered by vBulletin®
