Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Weak TX on Lincoln HR2510
Reply
  #1
Old 07-23-2010, 10:42 AM
Junior Member
cerapcic is on a distinguished road
Default Weak TX on Lincoln HR2510
Hi to all.
I searched all day for answer and nothing.
I have President Lincoln radio that has had blown output and driver transistor along with copper traces and one bias resistor. I replaced driver 2sc2166 and final 2sc1945 from Eleflow technologies but output is now very weak and RX is working nice.
After hours of thinkering and soldering I could not find solution. So if anybody has any idea please let me know.
How i troubleshoot it:
1.Turned radio on an measured output and it was very weak (around 3mW)
2.Started measuring DC voltages along chain of output transistors and everything is according to specs.
3.Started measuring AC voltages on bases and collectors on chain of transistors after IC106 and this is where becomes very strange.
Output of IC106(PIN 9) is around 640mV rms
Q134 base(83mV), emitter(90mV)
Q124 base(79mV), collector(340mV)
Q133 base(40mV), collector(170mV)
Q132 base(20mV), collector(150mV)
Output on antenna with connected dummy load is 375mV
(Notice that after each coupling between transistors lot of signal is lost)
4. Started to inspect inductors,chokes and capacitors everything is fine(even removed glue)
5. Changed all el. capacitors in TX output section and ceramic that are in RF path
6. started to get very frustrated...
Nothing is changed. Everything is the same as it was when i replaced burned components.
I know there are some real gurus here so I would appreciate any help.
Regards
Marjan
  #2
Old 07-23-2010, 07:42 PM
Quiksilver's Avatar
Senior Member
Quiksilver is on a distinguished road
Default
Rogerbird1 is the Lincoln/2510 man. PM him, or hopefully, he'll chime in...
  #3
Old 08-05-2010, 03:50 AM
mechanic's Avatar
Senior Member
mechanic is on a distinguished road
Default
Did you replace the pre driver? Check for burned traces on the SWR board, bad or cold solder joints on the inductors. There are usually two ceramic caps on the underside ( speaker hole) of the chassis, these could be bad or shorted. Check for proper voltage on the B+ rails supplying the finals.
I'll think of more!
73 mechanic
I'm apathetic, and I don't care!
  #4
Old 08-06-2010, 01:09 AM
Senior Member
Robalo is on a distinguished road
Default
the pre-driver is q31 2sd2086d i know there too many radios upthere with the same problem low tx power about 2-3 watts butt no one tell us what the problem some people said is cold solder around the pa but i dont have luck to find it
http://www.worldwidedx.com/tech-repa...t-wattage.html
http://www.worldwidedx.com/tech-repa...-dropping.html
__________________
  #5
Old 08-06-2010, 11:09 AM
Senior Member
Rogerbird1 is on a distinguished road
Default Final
The Output Final is incorrect, the Original output is a MRF477 and can be replaced with a MRF497 - Those are the pin for pin replacement. The transmitter is designed around these finals. I have found no other fully suitable final. The Bias and tuning is best with these.
I have used a MFR455 - But it is a different case style and will only give minimum output with out some serious drive reconfiguration. (only about 10 to 12w)
You should be able to get a MRF497 from RF Parts for about $30.
Roger
  #6
Old 08-07-2010, 12:57 AM
Junior Member
Default
Thank you all for reply.
Mechanic: I replaced the pre driver (manufacturer was PMC) but as I recently discovered it was fake 2sc2166 so i ordered original Mitsubishi from e-bay so I hope it will cure the problem.
Rogerbird1: I replaced MRF477 with 2sc1945 as this video shows:
I will let you now what is going on with the radio as soon as new 2sc2166 comes.
Regards
Marjan
  #7
Old 08-16-2010, 08:23 AM
Junior Member
Default
Hi all again.
So a have replaced 2sc2166 with genuine Mitsubishi one and now i have 1w output on AM after made all adjustments. Current draw by radio is around 1A from 13.8 supply. Obviously some other component is malfunctioning, and I have changed almost everything(See first post).
Any suggestions?
Regards
Marjan
  #8
Old 08-19-2010, 07:16 PM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
Quote:
Originally Posted by cerapcic View Post
Hi all again.
Any suggestions?
Regards
Marjan
have you checked frequency of output? it may be one of your oscillator signals entering the tx mixer is low or missing.a power meter can't measure frequency,and a radio will never give full output if its only amplifying one of the mixer signals as it will be far too far off the tuned circuits in the final stage to give any decent power.
__________________
"IT WON'T BE EASIER TO SPREAD YOUR VERSION OF HOW SH*T TICKS"
BOB85-2010
Reply
Bookmarks
Tags
defective, lincoln, president, radio
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lincoln HR2510 - defective DL1GKD Export Radios 9 12-28-2011 08:52 AM
Lincoln vs 2510 Wire Weasel Export Radios 11 12-03-2010 06:13 AM
lincoln audio fault fodendaf General CB Services Discussion 6 05-11-2010 09:31 AM
WHICH IS A BETTER RAIDO A HR2510 OR A LINCOLN??? AM POWER General CB Services Discussion 3 02-25-2004 06:50 PM
Powered by vBulletin®
