Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
RCI-2970N2 NEW BLACK DISPLAY
Reply
  #9
Old 09-05-2010, 08:12 AM
triple nickel's Avatar
Senior Member
triple nickel is on a distinguished road
Default
Quote:
Originally Posted by Robb View Post
So it must be true of the claims that the IRF-520 device is good for 50 watts each. Hmmm. I see the heat sink issue to be part of the problem. That being said, I can see that they may change out the 'low profile' type heat sink and provide something with a little more meat on its bones - so to speak. Maybe a better heat sink compound would help too. I know a few locals that had bought the Magnum 257's - and then added a small computer fan to the heatsink - attaching it with drywall inserts. The RFX-75 may be able to produce 120 watts as some claim; but safer to run it no more than 75-80 watts. Ya gotta do - what ya gotta do...
I know a few people that use a Turner+3 on these radios with very nice results. They also adjusted the AMC on it as well.
Did you say that they fixed the white noise problem that it had?
You didn't say if the color of the LCD screen could be changed to another color?
Can the clarifier be unlocked?
Sparky's CB Shack does unlock the clarifier on his Rci-2950dx-2970n2
  #10
Old 09-05-2010, 09:54 AM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
Quote:
A pointless modification when the radio has a VFO.
  #11
Old 09-05-2010, 10:48 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
That depends on how lazy one person is, I personally prefer the clarifier unlocked for stations that are just a touch off frequency but for privacy the vfo option is a +.
  #12
Old 10-29-2010, 11:53 PM
76Q 76Q is offline
76Q is on a distinguished road
Default
The design specification for the 8 mosfet exciter is 65 watts max deadkey on AM and swing max 200 watts. Why someone thinks they are smarter than the electrical engineers who designed the amp section is beyond any reasonable thought. Also there is a maximum duty cycle for using max power because the fan section stops running every time you key up the RCI. In the service manual they advise no more than 10 seconds at a time while tuning the transmitter at max power and test modulation. From this information, it would be wise not to key up at max 65 watts dead key and modulate at 100% for more than 10 seconds. In normal speaking rate average modulation will be far less. I certainly wouldn't play a 5 minute loud music piece over the transceiver at max power, much less scream into the mic for that long. So for normal use, I gather that the transceiver will last indefinitely if working normal speech at normal intervals at full power in room temperature. I've done this with the same amp section in another RCI radio and the transceiver gets warm but never hot.
The RCI is made to a tight high technology specification down to the last switch and knob, something you won't find in any export these days, including Galaxy, save for the common shared sections like the amp and echo board, etc with RCI. Used according to design spec, The RCI radios will outperform their competition in quality audio, stability, receiver quietness and sensitivity, and refinement in the human interface (knobs, buttons, etc.). RCI has the edge all around, its just that the users are demanding much more than the already stellar performance of the RCI radios. Overdoing something that already beats the competition is rediculous. You already have the absolute best in exports when you choose an RCI. To push the envelope further is like fighting a ghost, a non existing competitor. The challenge to push the radio further is best left with its designers and engineers and engineering techs that made this. Golden screwdriver types are doing something like putting nitrous on a McLaren F-1 ~ the refined design cannot accomodate this quasi detuning without breaking. The tolerances are high and should not be disturbed without thorough re-engineering. JMO
  #13
Old 10-31-2010, 05:27 PM
Senior Member
hotrod is on a distinguished road
Default
Quote:
Originally Posted by cbradiomagazine.com View Post
Short vid and some pics of the new RCI's with the back display and expanded memory storage
i wonder if there gonna do this with the 2950dx.
__________________
BASE-emperior 5010,sirio 2016
MOBILE-ss3900,sirioz180,astatic 636SE
  #14
Old 02-05-2011, 10:00 PM
Junior Member
arod27pr is on a distinguished road
Angry I Just GOt Burned!!!
After only 6 weeks of use, my N2 just shut off n died, I taking it to the shop that Sold it to me on Monday n see whats up, I hope warranty Does cover it, i haven't touch it at all, I didn't even took off the screws.
If it is the mosfets that got messed up, r there are any other that i can replace the stock ones to better ones?
  #15
Old 02-09-2011, 10:45 PM
Tyronza Boy is on a distinguished road
Default
Very, very, very WELL said.
Reply
Bookmarks
Tags
10m radio, rci-2970n2, review
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problems with NEW RCI 2970n2.. Mr. Doug Export Radios 32 05-09-2011 09:47 AM
RCI 2970N2? Nuke Man Export Radios 45 12-11-2010 05:12 PM
RCI 2970N2 zinger827 CB Radio Gear SwapShop 0 04-04-2010 05:07 PM
Powered by vBulletin®
