Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
Tech Help President Jackson
Reply
  #1
Old 10-17-2010, 04:24 PM
CTStallion's Avatar
CTStallion is on a distinguished road
Default Tech Help President Jackson
Folks,
A friend of mine gave me his President Jackson to look at because of no RX or TX. The Jackson is a 5 band AM/FM/SSB transceiver.
This radio has special meaning to him, as was his late Father's.
Anyway, radio lights up and works good on PA mode, but no TX or RX. Last time the radio had trouble (1997?) it was for cold joints in the VCO area. Checked for same and 'resoldered' everything in the area.... nothing.
I also replaced the oscillator crystal..... nothing.
Should've checked the caps and/or transmit/rx transistor (if so equipped), as the RX light works on RX, but the TX light does NOT come on when I key the mic in any mode.
The service manual on CB tricks is pretty 'light' for this radio... dunno WHERE to start.
Any suggestions before I start swapping components to find the fault? (I'd really like to help him out w/this.)
Thanks
__________________
Icom, Heathkit, Ameritron & MFJ HF Gear
Kenwood, Yaesu, & Alinco VHF/UHF Gear
Ranger, Galaxy, Uniden & Cobra 10 - 12 Meter Gear
Ten-Tec 'T-Kits' (love the lil buggers!)
Lotsa Homebrew & Tube Gear
Homebrew Antennas (HalfSquares, Bazookas, Wire Arrays) HF & 6M
Shakespeare ABS-1600 Army Stick 10 - 12M
Hustler & MFJ VHF/UHF Antennas
  #2
Old 10-17-2010, 06:50 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Did you try a different microphone before going through all that soldering work??
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 10-18-2010, 04:53 AM
CTStallion's Avatar
Default
Quote:
Yes sir, sure did.
In fact, the PA function works fine as well on all mics tested.
__________________
  #4
Old 10-18-2010, 05:23 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
You might check the center stand connection between the so'239 and the board for a cold joint.
  #5
Old 10-19-2010, 06:01 PM
CTStallion's Avatar
Default
Bump
for visibility
__________________
  #6
Old 10-19-2010, 08:02 PM
kb6led is on a distinguished road
Default
check to make sure you have voltage to the PLL
  #7
Old 10-19-2010, 08:18 PM
TonyV225's Avatar
Default
check all the solder connections on the pins to the PLL chip on the foil or flatside of the board. Use something non metalic (non metal) something plastic or I use wooden doll stick and push around gentley to flex the board looking for bad trace if this is the case which in most cases it is as you push that certain spot you will here sound come in and out.
this will give you a general starting point of tracking down bad or cracked traces or solder joints usually to a ground.
__________________
  #8
Old 10-19-2010, 08:48 PM
CTStallion's Avatar
Default
Quote:
I think THIS may be the problem, as I 'think' the VCO is looking to see approximately 6-8 volts, (changes as you change bands / channels), but I'm only seeing about 5 with NO change when I change bands.
Will a 2SA1012 replace a 2SA473? (cuz all I have in stock are 1012's)
From what I gather, the VCO won't work unless it sees at 'least' 6 volts or so, and (as you mentioned) the PLL has to LOCK at a certain voltage. I believe the output of the 2SA473 in this rig is supposed to be approx. 8 VDC.
Update: Changed the TR501 2SA473 with a known good NTE153, and replaced the 2SC945 TR34 with a new one. No change. Still developing only 5VDC to the VCO; PLL still won't lock. Going to local supplier to get subs for TR31 and TR33 to see if I can then develop voltage.
Getting the full 13.8V to the TP band to the final. Unfortunately the final is an MRF477, so still keeping my fingers crossed for the guy.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Silver faced President Jackson ExitThirteen Export Radios 26 07-18-2011 08:37 PM
2 President Jackson Exports SALE!!! 15minigrass CB Radio Gear SwapShop 1 05-13-2010 02:05 PM
President Jackson white face Flying Dutchman CB Radio Gear SwapShop 0 02-16-2010 09:08 PM
President Jackson Help saint7ds General CB Services Discussion 3 08-31-2004 07:08 AM
Powered by vBulletin®
